Thread: can any pool issue mess with pool deck? pic inside
    Was walking around my pool tonight and noticed one portion of the edge of my pool deck (away from pool, where it meets the grass) had concrete that looked a little bubbly/unsmoothed. I've never looked at this section closely so maybe its always been there and it was just a bad concrete job when built...thought I would post the pics and see if anyone thought something might be going on! pool is about 14 years old. thanks.
    Re: can any pool issue mess with pool deck? pic inside
    It looks like the concrete has been finished with a decorative coating like a Kool-deck or acrylic coating. Most likely, the section in question is just excess from the application.
    Support the site
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    That could also be push-out below the forms. Normal, though not aesthetically pleasing.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Definately excess concrete. Just add some topsoil to cover it up.
    18' x 36' saltwater inground vinyl pool
