Thread: Why do they suggest cpvc for the intelliflow pump?
    May 2012
    Oconee, Georgia
    82
    Does this mean they want this for the full run
    18'x36' inground vinyl liner.Pentair Sand Filter SD-60, Pentair EastTouch IC40 Salt Gen.
    Pentair Legend Cleaner. Pentair SuperFlo 1 hp pump. Color LED pool light.
    Taylor K-2006 (FAS-DPD) w/ SpeedStir. Pool Built October 2013.
    Re: Why do they suggest cpvc for the intelliflow pump?
    Normally you just use a short piece of CPVC, several inches, screwed into the pump and then switch to regular PVC. CPVC is stronger so it handles the threaded connection more reliably, and it is more heat resistant, so it won't melt as quickly if the pump gets really hot.
