Thread: Calculate savings of changing pump motor (1 to 2 Speed)
    Michigan
    83
    I have been looking at a lot of posts trying to understand how to quantify the electric savings of replacing my one speed motor with a two speed motor. (Retain Existing Pump) Below should be all the data required to calculate the savings but I just don't have the understanding of my electrical costs to figure it out. I'm sure it's a quick calculation for someone who understands all this stuff so any input would be helpful related to the savings or my plan to change the motor.
    Pool is in Michigan so it's closed in the winter months
    I have a electric Cover
    Pool Installed in 2004 (20x40 Hopper pool with spill over spa)
    Hayward SPX2610X15 (1.5 HP Single Speed Pump) 56J Frame (Replaced Motor in 2007 and again in 2009)
    Jandy Aqualink System with Aquapure
    I run the pump about 9 Hours a day
    Detail of my last bill that was $119.77
    Current Charges
    Power Supply Charges:
    Power Supply Energy 493 KWH @ 0.06912 34.08
    262 KWH @ 0.08257 21.63
    Renewable Energy Plan Surchg 3.00
    Other Power Supply Surcharges* 5.66
    Delivery Charges:
    Service Charge 6.00
    Distribution 755 KWH @ 0.05003 37.77
    Energy Optimization 755 KWH @ 0.002664 2.01
    Other Delivery Surcharges** 5.01
    Residential Michigan Sales Tax 4.61
    Total Detroit Edison Current Charges 119.77
    Service Period Mar 15, 2012 - Apr 13, 2012
    Days Billed 29
    Meter Number 5447257 09
    Meter Reading 17363 Actual - 18118 Actual
    KWH Used 755
    or around MAY 14, 2012
    Questions I am trying to answer:
    1. What two speed motor should I replace with ? Do they make energy efficient and non-energy efficiant two speed motors like the single speed motors? Any specific recommendations ?
    2. If I change to a two speed motor how much would my monthly electric bill go down ?
    3. I have extra relays in my Aqualink so can I wire the two speed motor to it and use the remote to automatically change speeds when I enter functions like "Spa Mode" ?
    20*40 Liner 2'-8' deep, Spill Over SPA, Electric Cover, Jandy Purelink (Aquapure & PDA), Hayward SP2610x15 (1.5HP Single Speed), Hayward H300 (Millavolt)
    Re: Calculate savings of changing pump motor (1 to 2 Speed)
    Your pump draws something around 1300 watts, times 9 hours a day is a little over 350 kWh/month. You are paying about $0.16/kWh, so spending perhaps $56 per month on the pump, in the months that the pool is open.
    1) Yes, they make both energy efficient and not two speeds. Energy efficient versions have about a 10% savings in electricity.
    2) Switching to a two speed pump will save your right around 50% of your pump costs, so about $28/month that the pool is open.
    3) Yes.
    Michigan
    83
    Thank you so much for calculating the difference in cost ... It would have taken me forever. If anyone has recommendations for a two speed motor and where to get it reasonably priced please let me know.
    Thanks
    I just went through the same upgrade of a Hayward Superpump 1.5 HP single speed motor (SPX2610X15) to a 2 speed motor. I sent you a PM on this as well.
    I went with an AO Smith 2 speed motor and a new seal kit. I only had a standard time clock control so I also upgraded my controls to an Intermatic P1353ME. This will handle the motor on/off as well as the hi/lo speed control. AO Smith was the manufacturer of the motor that came on my Hayward Superpump. I'm sure yours is the same.
    I hope this helps!
    JP
    Jun 2007
    New Jersey
    653
    I just replaced the 8-year old single-speed on my Pentair WFE-26 1.5hp uprated WhisperFlo with an A.O. Smith high efficiency 2-speed from http://www.ezpoolz.com/categories/Pu...s/Pool-Motors/. They had the lowest price I could find on the web for that motor and I got exactly what I wanted shipped the next day. It's now in and working perfectly. I just went with a manual switch from Granger for $5 to control the speed. I'll leave it on low except for vacuuming and backwash.
    I really think the A.O. Smith high-efficiency 2-speed Centurion is the best bang for the buck.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
