Results 1 to 16 of 16
Thread: Just Opened - Test Results
    Feb 2011
    Cincinnati, Ohio
    106
    I just received my TF100 kit today and used it right away. Here are my results.
    TC - 0
    PH - 7.8
    TA - 210
    CYA - I used the entire drop bottle in the sight glass and still saw the black dot fine so I would say 0
    I still need to get it scrubbed up better. When I removed the cover there was some algae on the fiberglass steps. Water is fairly clear.
    Pool was built last summer and this is my first year opening it. What should I do first?
    Should I raise CYA before shocking? I need to get my SWG going too but figured I need to shock first.
    Any other advice would be great.
    18 x 36 IG Vinyl Liner 28K Gallons
    Pentair Intelliflo VS+SVRS, Pentair CC + 420 Cartridge Filter, Easytouch CP with IC40 SWG
    2" Suction and Return Lines - 2 skimmers, 6 returns
    Dolphin Diagnostic Advantage Robot
    Re: Just Opened - Test Results
    I suggest starting by lowering PH to 7.2. That will also start lowering TA, which is rather high.
    Then you want to start shocking and start adding CYA at more or less the same time. Shocking without CYA isn't very effective And CYA can sometimes break down if you add it without adding any chlorine.
    Feb 2011
    Cincinnati, Ohio
    106
    What is the best way to raise CYA? Liquid or solid?
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by briansturgeon
    We generally recommend the solid/powder/granular form added via sock method.
    The liquid is faster, but pricy.
    You're done SLAMing when:
    Feb 2011
    Cincinnati, Ohio
    106
    The pool calculator said I would need 234 ounces by weight of CYA. That seems like a ton to me since that is over 14 lbs. Does that sound right? Is it possible to have a CYA of 0. I know I never added any last year. I just want to make sure I'm not messing something up because I know the only way to lower CYA is to drain water and I don't want to get to that. Thanks.
    Butterfly's Avatar
    South Carolina
    10,045
    I suggest you add only about 30ppm CYA and start shocking at the same time.
    Adding all needed CYA at this time only costs more $ for the shock process as a higher CYA level has a higher shock level, which requires more chlorine ($).
    When you are done shocking (see red lines in my sig) you can then raise the CYA to about 70ish for the SWG. Don't use the SWG for the shock process, use liquid chlorine/bleach.
    And yes, about 234oz of CYA will add about 63ppm CYA to a 28K gallon pool.
    Are you familiar with the "How to Shock Your Pool" article in Pool School?
    Post back with any questions. Someone will be around to help
    Feb 2011
    Cincinnati, Ohio
    106
    I have read the shock process but I'm still trying to figure out how much bleach to use. So how much bleach should I start out with? I am having trouble figuring that out after using the calculator. Since my CYA is currently 0 even though I will target 30 at first should I base my initial chlorine dose on CYA 30 or 0? Don't want to mess anything up.
    Butterfly's Avatar
    South Carolina
    10,045
    With zero CYA, shock level is about 10.
    After the CYA is dissolved from the sock, assume it is in the pool and adjust the shock level accordingly.
    CYA can take up to a week before it shows up on a test, so don't waste your reagents.
    Feb 2011
    Cincinnati, Ohio
    106
    does 581 ounces of bleach sound about right to you then? Thanks for all the help.
    Butterfly's Avatar
    South Carolina
    10,045
    yep, per poolcalculator.com that would take your FC from zero to 10ppm.
    Feb 2011
    Cincinnati, Ohio
    106
    Ok. Headed to Wally World now.
    Feb 2011
    Cincinnati, Ohio
    106
    So sorry but have one more question I forgot to ask. Should I unplug my IC40 SWG while shocking? Will it hurt it or anything?
    Feb 2011
    Cincinnati, Ohio
    106
    Question on Shocking and SWG
    Ok. Here are the readings from today. I have a couple of questions too.
    1. My SWG is currently on. Should I turn it off in order to get my FC back down to target level?
    2. I did the overnight test and lost 0 FC and there are still no CC. Does this mean I'm done with shocking?
    3. How do I lower my TA. I added acid to get my PH in line now what for TA?
    4. Should I increase calcium a little bit?
    FC - 15
    PH - 7.2
    TA - 180
    CH - 190
    CYA - Added 8 lbs yesterday
    CC - 0
    1) You can if you want, but it is simpler to just leave things alone.
    2) Yes.
    3) See the article on lowering TA in Pool School.
    4) There is no point as you have a vinyl liner pool, which doesn't need added calcium.
    Feb 2011
    Cincinnati, Ohio
    106
    Will my FC come down on its own then so we can swim soon?
    Your CYA level can't be all that high yet, I would expect several hours of sunlight to bring the FC level down quickly.
