Thread: How much liquid chlorine to lower 1 lb of AA
    Aug 2008
    Honolulu
    429
    How much Walmart 6% liquid chlorine in fluid ounces does it take to neutralize 1 lb of AA in a 10,000 gallon pool after AA treatment?
    Apologies I know the answer is here somewhere in the forum but I cannot find it.
    Thank you.
    10,000 gal plaster pool,3/4 hp WhisperFlo pump, Sta-Rite Great White GW9500 pool cleaner, Hayward 300 lb Sand Filter
    Use Magenta Stuff for Iron and Silica control.
    Balance: pH 7.7 Cl 7 -8 Alk 70-80 CH 325 CyA 30 in winter - 50 in summer NaCl 1010 TDS 1200
    South Central NJ
    3,192
    Re: How much liquid chlorine to lower 1 lb of AA
    Bleach doesn't neutralize AA, baking soda and washing soda (dense ash) do. Go by your pH and alkalinity levels. I suggest using the pool calculator (www.poolcalculator.com) to do it.
    Scott
    Owner of - PoolGuyNJ LLC
    Chlorine and ascorbic acid do destroy each other, quite rapidly as it happens. That isn't the same thing as neutralizing an acid with a base, but it is valid to call it neutralizing.
    3.5 oz of ascorbic acid will neutralize 1 ppm of chlorine in 10,000 gallons of water. So I get 3 quarts of 6% bleach. However, I don't have anything to double check that against.
    Aug 2008
    Honolulu
    429
    Thank you to both of you for the quick answers.
    I also get about 3 quarts.
    Support the site
    Mar 2007
    San Rafael, CA USA
    12,082
    100 fluid ounces (3-1/8 quarts) of 6% bleach neutralizes 1 pound of ascorbic acid.
