Results 1 to 7 of 7
Thread: Timer Problem
    Guest
    Timer Problem
    Hello -
    Don't know if anyone else has seen this issue: The timer dial on my main pump is bending the "off" pin when it contacts it to turn the pump off at the designated time. The pin should trip the on/off switch, but somehow the pin is getting bent and the pump keeps on running until you turn it off manually...
    22,553
    Re: Timer Problem
    What timer do you have?
    Guest
    Re: Timer Problem
    Intermatic PF1222TB Dual timer...
    22,553
    Re: Timer Problem
    That unit contains standard timers. I haven't heard of an issue like that before. Is it bending the tripper pin or the dial face? If it's the tripper pin, it has to be sumething pretty substantial to bend that.
    Re: Timer Problem
    Quote Originally Posted by wkener2
    Hello -
    ... The timer dial on my main pump is bending the "off" pin when it contacts it to turn the pump off at the designated time. ...
    I have seen that problem on my timer. I am not certain what caused it, but I suspect it was due to using tripper pins that are almost but not exactly the correct size. Did you recently replace or add these trippers?
    25,000 Gallon 20x40 in-ground vinyl lined pool circa 1980.
    Guest
    Re: Timer Problem
    Yes, about six months ago... but they worked fine up until a few weeks ago.
    Jul 2012
    CA
    240
    Re: Timer Problem
    Ever get it worked out? Im having a similar issue with spa timer.
    Nice catch btw. (avitar pic)
    25k I/G ecostar ccplus Polaris plaster
