Thread: Pool Shock Temperature
    Jun 2008
    Chicago, IL
    2
    What is the optimum temperature to shock a pool?
    Just opening pool.
    Water temperature: 57 deg
    Outside air: 40/65
    FC .1
    CC 5.2
    TC 5.3
    pH 7.2
    Should I heat pool before shocking?
    Thanks!
    32,000 gal 20x 40 pool Chicago,IL
    Pool closed From October thru May.
    Sand filter (changed July 2006)
    Natural Gas pool water heater
    Automatic chlorinator with 3” trichlor pucks. Phos Free – 2 cups a week
    30,401
    Re: Pool Shock Temperature
    You can shock now. The process may go just a bit slower but not enough to warrant the money to heat the pool.
    You sure have a hefty CC's test result. How does your water look? Do you know your CYA level to get to the appropriate shock value?
    Jun 2008
    Chicago, IL
    2
    Thanks for the reply.
    Pool is the usual cloudy blue. I don't know the CYA numbers. From past years experience I have found that 12gallons of pool shock will clear out the CC to 0.
    I pour the 12 gallons jugs into several 5 gallon buckets and then quickly dump it into the pool. Always do it after sunset. I've had good luck with this system, the pool shock will lower the pH so increaser is always needed.
    The amount of chlorine you actually need to use is highly dependent on your CYA level. It is well worth finding out what your CYA level is.
