Thread: Solar covers?
    Apr 2012
    Yakima, WA
    58
    Solar covers?
    I know they insulate the pool water at night to keep the water from losing heat. Do they also help heat up the water during the day?
    Thanks!
    Dave
    Yakima, WA (the Palm Springs of Washington!)
    IG kidney 14k gal, 33 x 18
    vinyl liner
    200 lb Sand filter
    3/4 HP pump
    First time pool owner
    Re: Solar covers?
    The main advantage of a solar cover is because it prevents evaporation, which is the primary source of heat loss. The cover also interferes with solar heat gain. Depending on how much sunlight shines directly on the pool (heat gain) and how much wind there is (large influence on evaporation), that can come out as an advantage or a disadvantage during the day.
    Apr 2012
    Yakima, WA
    58
    Re: Solar covers?
    Interesting, I guess "solar" cover is kind of a misnomer!
    Dave
    vinyl liner
    200 lb Sand filter
    3/4 HP pump
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    Re: Solar covers?
    The clear ones are best for some heat gain. Think of a car with tinted windows or clear ones sitting in the sun.
    solar-cover-thickness-pattern-help-t38686.html
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
    May 2012
    Arcadia, Ca
    50
    Re: Solar covers?
    interesting. so, remove the covers during the day and replace, at night, to maintain the temp?
    many, many years ago, when covers first appeared, we kept it on, during the summer, days at a time. quess what? turned to pea soup in color. when we swam, you sweat, it was so warm. (we swam before the pea soup!)
    24'x15' 4.5 deep (avg) 13000 gallon pebble bottom in ground playpool
    Cartridge filter with a hayward 2.5hp pump.
