Thread: Hayward Leaf Canister or Zodiac Baracuda
    Does the Hayward leaf canister or Zodiac Baracuda leaf canister connect to a standard vacuum hose for a hand vacuum? I still can't see the bottom of my pool and would like something that would allow me to see the dirt flow through the hose so I can tell when I'm vacuuming a really bad area. From what I have read it sounds like most leaf canisters are intended for use with an automatic cleaner. How do these two canisters connect to the hose and could they be modified to work with a standard hose? Thanks!
    15' x 30' x 52" Oval AGP; 1hp Hayward Powerflo LX Pump; Hayward Sand Filter; 4 2'x20' Sungrabber Solar Panels; Compupool CPSC36 SWG
    Jul 2010
    Central, New Jersey
    31
    Re: Hayward Leaf Canister or Zodiac Baracuda
    I have the Kreepy Krauly leaf canister. It came with a white adapter hose that lets you put the canister inline with your existing hose.
    You should be able to connect it to any hose no matter what vacuum head is attached to it. I have used mine with my hand/pole vacuum a bunch of times.
    -Craig
    Pool: 20 X 40 Rec - 28,500 gallons;
    Type: IG with Vinyl Liner
    Filter: Hayward 46SqFt DE Filter
    Pump Size: Hayward Super-Pump 1 hp
