Thread: Raising PH with Borax
    May 2012
    Phoenix Az
    4
    So i'm a fairly new pool owner, and I'm learning the BBB method. Pool is 10,000 gallon in ground plaster pool. I picked up pool Calc for my phone, and have been using it religiously ever since. Had one question though. So I read that to help keep the PH in balance I want about 30-50ppm of borax. Its also my understanding that Borax stays in the pool indefinetly, but I may be understanding that incorrectly. Well I need to raise my PH, and it seems that Borax is the substance of choice to do this, since it won't effect TA much, but if I do this repeatedly everytime I need to raise my PH, won't I end up with too many Borates in the pool? I'm sure I'm missing something, because there doesn't seem to be a lot of debate on using Borax to raise PH, and I couldn't find anything about Borates getting out of wack.
    Thanks
    10,000 gallon IG plaster pool with sand filter
    Re: Raising PH with Borax
    Welcome to TFP!
    It takes huge quantities of borax to change the borate level. The far smaller quantities used for adjusting PH are not likely to ever add up to anything significant.
    May 2012
    Phoenix Az
    4
    Thanks for the quick response.
