Thread: Concrete Sealer
    Concrete Sealer
    Well needed to get deck resealed, have lots of area so hired local contractor to do it. I have an electric cover so I told the contractor to roll the sealer on near the edge of pool and to stay away a couple inches. I reminded him several times, however as soon as he leaves the job his guy starts spraying near the pool cover. Anyways they did get some specks of sealer on the cover and probably in the water (it was near the edge where it closes). It was a acrylic diamond shield voc sealer. Anyway I can probably live with the specs more concerned about effect in water if a few drops got in. Will the pool filter remove any sealer that may have gotten in the water when I start it up next week? Would the water by safe to swim?
    26,500 Gal, Vinyl, Sand Filter, Haywood SWG, Automatic Cover, OHIO
    Re: Concrete Sealer
    What protective measures was the sprayer guy taking?
    18K Gals, Intelliflo VSD, Pentair Catridge, SWG, Solar & Gas Heat, Pebble Tec, Jandy AquaLinks, Pool Pal for Android.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Concrete Sealer
    Chlorine will break down the sealer in the water; I wouldn't worry about it. I'd be more concerned about the cover, since the solvents could conceivably eat away at the vinyl.
    Re: Concrete Sealer
    Quote Originally Posted by Melt In The Sun
    How would chlorine break down sealer in water? I don't think acrylic sealer is water based, so it should not mix. Does chlorine break down toxic chemicals in water. I thought chlorine is only a disinfectant for bacteria.
    After it is done curing in a few days would it still eat the cover?
    Oct 2009
    3,899
    Re: Concrete Sealer
    Chlorine oxidizes (breaks down) organic compounds, including petroleum products like sealer. It may take a while, but it sounds like you only had a tiny bit to start with.
