Thread: Bullnose Paver Coping
    I also have a steel frame liner pool, lagoon shaped. In Mass. I have a couple of questions. 1. I would like to put down 12" ideal bullnose pavers what type of mortar should I use? 2. There is about a 1" gap between the base material and the top of the steel frame do I put down mortar to fill gap and mortar on steel frame and then place the bullnose paver on top? Should I leave a space between pavers? 3. What about the white strip on the top of the steel frame does it get covered with mortar and the bullnose paver? 4. Will I be able to change the liner down the road if the bullnose paver covers the white strip? It will be my first time working with mortar I think I'll enjoy it. I was also told to place some expansion foam between the bullnose coping and the deck pavers. I think I can do this. Any advice/ tips would be greatly appreciated.
    Bob Grobolsek Sheffield Village, OH
    18x33 AG Oval - 18k
    Hayward SwimPro Voyager - 2HP - Dual Speed - 150 sqft Cartridge Filter
    Vision Pro mineral system/trichlor feeder
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Bullnose Paver Coping
    Welcome to tfp, Firsttimer
    I am sorry I can not answer your questions. I am sure someone will be along soon that can
