Thread: Intex pool ring valve
    My valve plug for the inflatable ring broke off and I have struggled to find a replacement. I went to my local Home Depot store today and found a part that is a perfect replacement. its a gray insert plug 3/4 in, item # 1449-007RMC made by Lasco fittings. This is to anyone else out there seeking the same replacement.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Intex pool ring valve
    Welcome to tfp, kelmom
    Thanks for sharing your find
    Thank you so much i have been trying everything!!!
