Results 1 to 12 of 12
Thread: "Extremely" Green Pool
    I know this post isn't going to follow the guidelines at the sticky of the thread, and this is because the pool in question isn't my own and right now I don't know anything about it, besides the fact its 30-35,000 gallons and has cartridge filters. I'm in an awkward situation where a friend of the family helped us out with our trees so somehow I got volunteered to take care of his pool, only because ours is "clear" and "nice" honestly I have no idea what I'm doing I'm just good at maintaining it, have been the last few years, but we have never really had major problems it’s easy to maintain something that doesn’t have problems.
    With that said, I don't know anything about the pool except that it’s extremely green with algae; the water itself has turned a green color. I know that last year he spent over 1600 dollars in materials for the pool to get it nice and clean (which he did) but then there was a horrible tornado in our town which made it worse, and he hasn't touched it since.
    I know he’s going to call me up soon for help. I just need to know some articles, or posts about what to do when the pool is completely green. I'm sure that no matter what type of pool it is the fundementals are all the same. I assume the first step is to clean up, kill, and get rid of the algae, but I don't even know how to go about doing that. Never had algae problems in our pool in 20 years, and not in the last few years I’ve been maintaining it.
    Any help would be greatly appreciated.
    30,000 Gallon, Above Ground, Vinyl, DE Filter
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: "Extremely" Green Pool
    Here ya go:
    turning-your-green-swamp-back-into-a-sparkling-oasis-t4147.html
    For your own sake, take a read through Pool School when you have a few minutes:
    pool-school/
    Quote Originally Posted by Melt In The Sun
    Here ya go:
    pool-school/
    Thank you very much. I've skimmed through the pool-school a few times in the last couple years, I really needed a good detailed read on green algae. Thanks a lot!
    EDIT - Ok it says you need to bring the chlorine up to shock level and keep it there. What is shock level considered? Is it just entirely based on your CYA level and thusly just use the calculator?
    22,548
    That's correct, it's strictly based on your CYA.
    So basically just keep shocking it every 30 minutes. During this time you are supposed to skim and brush it says, but not vacuum?
    22,548
    You need to scoop all the debris out of it before you try to vacuum. And yes, test and bring it back to shock as often as you can. The more diligent you are at keeping it at shock level the faster it will go.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    First fish out as much as you can, gunk, leaves, limbs, bodies, chairs, etc. The less gunk in the pool the less chlorine you will have to use, scrub, vacuum, cleaning filters as needed (which will likely be often at the start), the idea is to let the chlorine get to the algae to kill it, you will likely need a lot of chlorine for this (a lot is hard to quantify though), you will want to raise it to shock level, and keep it there while scrubbing and removing as much gunk as you can. At fist the chlorine will drop below shock level very fast, the closer you are to finishing the longer it will maintain.
    Ike
    Don't be surprised if it goes from green to brown and all sorts of other colors before it clears up, you may want to get your pH in the right ballpark before starting, note pH test are not reliable at FC levels over 10-15ppm
    Ok thanks guys. I understand to get all the big globs of junk out of there first, but after that is done should I vacuum while still checking shock levels, or just leave it untill its all cleared up?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    scrub and vacuum the whole time, the more you remove by filtration the less chlorine you wil use up.
    Ok good deal will do. Sounds pretty simple in execution, even though it takes alot of patience and care.
    I was finally going to get a chance to use the "this thread is useless without pictures" smilie, followed by the "eating popcorn" smilies - but for some reason I can't get to the "more smilies." So, suffice to say, could you post some before and after photos?? And, good luck!
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    (finally figured out they were floating around on my desktop in the background)
