Thread: Dolphin brains in the rain?
    Aug 2011
    Northville, Mi
    312
    I've got a Dolphin and was wondering if it's okay if the 'brains' are out when it rains. The manual says "The power supply unit is splash proof do not immerse it in water." But I'm not sure if rain would be too much or not.
    Any thoughts?
    15,400 gal, 16x32 vinyl rectangle (sport dig), Intelliflo VS, 240 sqft cartridge filter, Intellichlor IC40, Mastertemp 250, Dolphin supreme M4 cleaning, Pentair EasyTouch4, Tested regularly and accurately with supplies from tftestkits
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Dolphin brains in the rain?
    Well, rain is a bunch of splashes, so I wouldn't stress too much about it. I'd keep it dry if I could though!
    As long as it is sitting right side up and not in a puddle it will be fine.
    38,242
    I try to keep mine out of the rain but it has gotten wet and still works ok. Just adding extra risk of a failure in my mind.
    MattM's Avatar
    Jul 2011
    San Diego, CA
    299
    Before I bought my dolphin, I called around to the various service techs in the local area to get their feedback....one of them claimed that nearly all issues with dolphins are a result of either not storing unit under shelter when not in use (in pool is definitely frowned upon - garage is preferred location), the motor breaking, or letting the power system get wet. So, I'd be very hesitant about letting the unit get rained upon.
    24K gallon inground gunite/pebble sheen pool, 34'x16' 4-7.5ft deep, 750sq ft solar, pentair ultratemp, intelliflow vs+, ic60, intellichem w/ acid pump, quad de 100, intellibright 5g, intellitouch i5-3s with Screenlogic2, 3" primary piping - 2.5" at equip pad, auto switched deep heating and main returns, automatic safety cover w/ electronic lock and embedded recessed undertrack, sealed stamped concrete deck, dolphin deluxe 5, started up December 2011.
