Thread: cynaruic acid
    cynaruic acid
    i have a 18,000 gal. vinyl pool. last fall my cyanuric acid count was about 45ppm. i opened my pool this spring and tested my water for cyanuirc acid was 0ppm. i was wondering because i live in iowa if you could lose acid because of winter conditions or is it normal to lose it. i do drain about 6000 gals. out in the fall, then i get this back be cause of snow melt and rain that goes through my meyco safety cover. hope for an answer. thankyou dick
    Butterfly's Avatar
    South Carolina
    10,045
    Re: cynaruic acid
    Yep, it does happen. Here's a recent thread:
    cya-disappearing-t42943.html
    You're done SLAMing when:
    Mike S
    Guest
    Re: cynaruic acid
    The CYA faries paid me a visit over the winter and swiped mine also. Went from 80 to 0.
    If you do some searching you'll see that we aren't alone. There is a bacteria that can consume it under certain conditions. In my case we had a very mild winter and I had a lot of leaf litter get through a hole in my cover. I'm guessing that contributed to it. I ended up with a green mess when I took my cover off on Sunday. I'm burning through a lot of chlorine and trying to the challenge up slowly.
    Re: cynaruic acid
    thanks for the info butterfly. it sure puts my mind at ease i thought i was losing my mind instead of acid.
