Thread: Questions about pool balance
    sprede's Avatar
    Jul 2011
    Nebraska
    34
    Hello,
    Last year I was helped by some of you to get my pool in balance and I thank you all greatly for that. This year I opened up my pool and started shocking according to how you all explained it to me the first time. I had been 2 days without CC drop, less than 1 FC drop and the water is clear then I found out that I had left my SWG turned on so that is why I have the high FC count. I turned it off May 8 which is why you see the drop in FC. Anyway, my concern is the HIGH TA reading, I can't seem to get it down or is that something even to worry about?
    May 7 Morning May 8 Morning May 9 Morning
    FC - 15 FC - 15 FC - 11
    CC - .5 CC - .5 CC - .5
    TC - 15.5 TC - 15.5 TC - 11.5
    PH - 7.2 PH - 7.2 PH - 7.2
    TA - 160 TA - 160 TA - 160
    CYA - 70 CYA - 70 CYA - 70
    How to get TA down to acceptable levels for salt water pool? Is there some home chemicals to use to get it down?
    ____________________________
    sprede,
    Intex 15'X48" / 5300 gal above ground metal frame Vynl pool
    Intex 1600 GPH Sand Filter with Intex SWG
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,075
    Re: Questions about pool balance
    Keep an eye on your PH....which looks to hold around 7.2. If you stay's at a set point....don't worry about your TA. If it starts jumping all over the place and quickly goes up....then worry about your TA.
    To lower it....go to pool school.
    pool-school/lowering%20total%20alkalinity
    sprede's Avatar
    Jul 2011
    Nebraska
    34
    I had been doing that per the pool school but it had only lowered by 10 after two trys. After reading that article a little closer it looks like it can take weeks to get it down to normal levels. Thanks for your advise.
    sprede,
    Aug 2011
    Texas
    45
    Mine took about 4 days to get it down from 120 to 70.
    12k gal gunite, Sunstone Plaster, Pentair IntelliFloŽ VS+SVRS Variable Speed Pump, Pentair Intellichlor IC-40, Pentair CCP520 cart filter
