Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: Our first pool... 41' Mountain Lake [FINAL PICS ADDED]
    Mar 2012
    Central NJ
    31
    Hello,
    Been reading this topic a lot since I joined recently and we made the jump.. Our PB started yesterday. I'm sill new on this forum and completely green on posting pictures... so go easy on me.
    It is a 21x41 "Mountain Lake" type of pool (goes to 8').
    Here are the basic specs:
    Filter Pentair TA60D
    Pump Pentair SuperFlo 1.5 hp
    Chlorinator Hayward CL-220
    light IntelliBrite 5g LED
    Liner 27 mil Dynastie/Blue Granite
    2 main drains
    2 multidirectional hydrostream return inlets
    2 wall skimmers
    2 in-floor cleaning heads
    Heating: 500sf Solar panel install
    Here are some of the progress we got since yesterday and today.
    We found out that the yard is slanted more than expected so that leveling will be needed.
    Few pictures of the construction, this is after all "Under Construction"
    Yesterday:
    Digging started.. easy enough
    Yard starting to look like a mess
    A couple of hours later we hit water! Was expecting it based on our area, but still... that was more $$$
    Excavation co went and got gravels and started pumping.
    Today:
    Wall went up really quicly:
    Followed by cement/Vermiculite
    And the filter/pump. Now do we have a problem here?? The PB did not use any primer on any of the PVC. I asked him, told me not needed! What do you guys think? Inspector is coming tomorrow, but from reading some of the posts, no sure he'll say anything. I don't know what to do on this one...
    So here we go for my first post... More to follow
    21'x41' Mountain Lake, Filter Pentair TA60D, Pump Pentair SuperFlo 1.5 hp, SWG Pentair IC-40, light IntelliBrite 5g LED, Liner 27 mil Dynastie/Blue Granite, 2 main drains, 2 multidirectional hydrostream return inlets, 2 wall skimmers , 2 in-floor cleaning heads, Heating 500 sq Techno-Solis Solar Panels, Hayward Aqua Solar control
    38,475
    Re: Our first pool...
    There are some PVC solvents that do not need primer ... although I still prefer it. Can you see a container of what they used? The inspector may or may not have anything to say about this ... are you going to be there where you could point it out and ask?
    Being that a few of the PVC joints done by the previous owner of my house have actually come apart with not sign of primer (although who knows what solvent was used) ... hopefully your pool builder did a better job.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, Nomdeplume
    I know primerless pvc solvents exist, but I have not used them.
    Mar 2012
    Central NJ
    31
    I went to look, the glue can is there, instruction do say to prime first...
    I guess all the piping will be encased for a good part in concrete so probably can't move much... but still. Got me worried now.
    Our first pool...
    I know "Christy's Red Hot Blue Glue says it does not require primer unless required by local code" on the can. I use it anyway.
    Under construction DIY 20x40 vinyl liner steel wall pool, Pentair 2hp wisperflo, Pentair tr100 sand filter, Pentair Minimax 400k heater, diving board, 8 foot sit n step, xtream waterslide, 1700 concrete deck, one amazing wife, 4 children and two German shepherds.
    22,553
    Re: Our first pool... 41' Mountain Lake, Solar panels
    Just for an opposing opinion (and an opinion is all it is) I never use primer and have never had a joint leak in the 15 years since I stopped using it.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    To add my own experience: I've never had a joint leak because of no primer (I've done it both ways), but I have had some really infuriating joints leak because of using old glue. If it isn't runny anymore, toss it!
    Mar 2012
    Central NJ
    31
    Great, thanks to all for sharing your experience on the PVC glue. I feel a lot better! Plumbing Inspector just came by, I asked him, he thought it was a non issue as well.
    We have now passed both plumbing and construction and waiting for the weather to clear for the liner.
    On a different note the temporary pump taking water from the gravel under the pool (we hit water) quit overnight. Water started rising in the pool (8" or so) I tried to reprime it for an hour... no good. The PB came to try and it seized on him. They installed a new one and all the water is gone.
    30,431
    Yeah, I saw that pump in the pics and I think he was using an old pool pump he had around rather than a trash pump. Absolutely nothing wrong with that on your part......just that a pool pump usually cannot take too much dirty water without siezing up.
    Just from your pics (good ones, too) your PB's work looks nice and neat and clean to me. I think you have a good one.
    Sep 2007
    Central NJ
    59
    Not to be a naysayer or to cause undue worry -- just speaking to local conditions (weather and ground water) and raising a question.
    Central NJ has been extremely dry for several months and ground water levels are quite low for this time of year. So to see you hit ground water -- and that much of it -- raises a little bit of concern.
    Did your PB suggest an external drain from under the gravel to outside the pool boundaries (i.e., a dry well/sump) or did he at least discuss/advise on that possibility? That red Brunswick shale in your pictures is known to have banding/cracking through which water can flow at surprising rates. Some PB's in Central NJ, when they hit water, will wait a few days to see the level to which the water rises, then address via gravel/dry well if necessary.
    Floating liners do occur in this area (it happened to my neighbor). You might want to ask the PB before dropping-in the liner.
    Good Luck!
    Oct 2010
    Pensacola, FL
    67
    Pool pics look great, always fun to see work in progress...just curious why you didn't choose a variable speed pump, since it looks like you're doing this pool so nicely.
    Bill Moyer
    CWO4 USN (Ret)
    Pensacola, FL
    10k gallon 12x24 in ground pool built 2008, vinyl, Pentair Intellichlor IC40, Pentair Intelliflo v/s pump, Hayward sand filter. Using the BBB method.
    Mar 2012
    Central NJ
    31
    Quote Originally Posted by SteveK
    Good Luck!
    Thanks SteveK, not sure if this is what you meant or you suggest something else. Basically what they have done is poured tons of gravel with a flexible pipe embedded in in an overdig in the deep end part of the pool, as well as put gravel along the slope of the deep end. That flexible pipe coming from the gravel will be connected to the pump of the pool using a valve marked as emergency so that it can be used to pump if need be through the filter bypass (in case of issues with liner,...).
    Problem we are facing now with pumping under the gravel is that first temporary pump went (seized) and second pump which looked much newer overheated. They basically run fine for a while, then I guess water level goes down, they loose prime and start overheating. PB is coming back tomorrow to investigage.
    Mar 2012
    Central NJ
    31
    Quote Originally Posted by moyer02
    Thanks and good point if I had to redo it I would ask for that. My solar installer tried to warn me, but between the planning of the pool, solar, landscaping, shed, deck, yard regrading... head was spinning.
    Sep 2007
    Central NJ
    59
    Yep -- exactly what I was talking about....sounds like you have your ground water problem in check & are good to go!
    To alleviate any concerns of pumping dirty ground water with your pump -- if the 'emergency valve' also could simply be opened like a water faucet, chances are that any large amount of ground water would be forced-out simply by hydrostatic pressure. That option would be useful in late winter/early spring when ground water levels are highest. Your pump would not be in service at that time of the year. Just something to consider.
    Ground water levels and any related issues can be extremely localized -- its just the nature of the Brunswick shale.
    Good luck with the pool -- it does look terrific.
    Feb 2012
    Lancaster, PA
    112
    I just had the same shape installed, also with 1 Intellibrite LED light, but a smaller pool at 16 x 32. PB assured me it would be bright enough, and that I did not need a second light (it was suggested to me on this forum that I consider adding a smaller spa light on the steps). When we turn the light on, it fills the deep end with color but the shallow end remains on the dark side and does not fill with color.
    I found out afterwards while reading the owner's manual that the Intellibrite comes preset in the "Wide" angle position, but it also can be turned around into the "Narrow" angle position during installation. When installed on the longer side walls, the Wide angle should be used. When installed on the shorter end walls, the Narrow angle should be used (as per the owner's manual). My PB crew installed in on the preset Wide angle, and that is why I think our shallow end does not fill with light. We will have to remove our light to switch the angle, so I am just bringing it to your attention that you might want to ask you PB about it.
    16 x 32 vinyl In-ground Lagoon; Shallow pool 3' to 5'; Buddy Seat; IntelliBrite 5g LED; Pool Pilor Digital SWG, Pentair Clean & Clear Plus 320; Pentair Intelliflo VS + SVRS; Pentair Sand Shark. My Construction Thread - Spring 2012
    Mar 2012
    Central NJ
    31
    Quote Originally Posted by Stilly
    Thanks very much Stilly for bringing this up! Appreciated. I'll make sure to check it's set on "Narrow". This is one of the great thing about this forum I find, so much experience can be shared and learn from each other.
    Feb 2012
    Lancaster, PA
    112
    Quote Originally Posted by NomDePlume
    You're welcome. I realized that I have a photo of the colored light on my construction thread. You can see on page 2 how dark the shallow end is. 16-x-32-vinyl-installation-t42194-20.html
    Mar 2012
    Central NJ
    31
    Re: Our first pool... 41' Mountain Lake. Backfill question?
    Hello,
    [Sorry the pictures seem to be on the bigger side, I will try next time to shrink them even more] We have had really bad weather here in the North East, loads of rain, so we got delayed. PB came back and a few things happened. I wasn't there for the actual construction. So this is what I found when I came home: Liner got put in, concrete footing poured, and posts to support deck near pool. Also bonding for pool structure and accessories (ladders, diving board). LED light got rough wired as well and thanks to Stilly PB is changing the lens to Narrow!
    Pool is starting to get filled. This is done from a well, so PB asked me to do 3 hours on/1 hour off during the day and off during the night.
    Here are the 2 pumps setup for the liner.
    Loads of posts to support the future concrete deck!
    For a short while.. we almost had an infinity pool!
    Pump/filter are now pretty much all connected, in the background you can see the temporary pump connected to the gravel below the pool.
    We really have a lot of shale... This is one of the worst spot of all the piles though, but still I'm a bit concerned on using this to backfill after reading the threads on this forum on the subject. Any opinion on this? Should I ask to get some gravel put in?
    Next step I is backfill and finishing to fill the pool, but weather is suppose to be real bad next week, so I'm not sure when it will happen! So much sill to do!
    Alynn's Avatar
    Jun 2010
    Jacksonville, FL
    52
    Not to hijack your thread, but Stilly, can this be changed after installation? Ours needs to be changed, as well.
    And if can be done now, what is the procedure, please?
    Any and all help is appreciated!
    Alynn
    22,000 Gallon In Ground with CrystalStone (pebble) finish in Blue Ice
    Pentair 1.0 HP Pump
    Hayward C1200 (120 S.Ft.) Cartridge Filter
    Pentair Great White Automatic Pool Cleaner
    TF-100 Test Kit
  20. Back To Top    #20
    Casey's Avatar
    SW PA
    10,457
    You have a gorgeous pool! I'm really inlove with this shape too!
