Thread: FAS DPD test
    Apr 2008
    Arkansas
    13
    FAS DPD test
    What does it mean if I get no color change when adding 1 heaping spoon of 870 powder, then two. No change to pink. This has happened only this last test. Previous test 3 days ago showed up fine.
    FC, CC, TC ?
    PH 7.8
    TA 100
    CYA 40
    22K Gal double roman IG, vinyl, 300lb Crystal-Flo sand filter, 1 hp Sta-Rite pump, WF on pool side with 1.5 hp Challenger pump.
    Re: FAS DPD test
    That means that FC is probably zero. To find out CC you need to continue with the test.
