Thread: No Flow on SWG Display
    Running a SWG for a 32,500 gal pool. PSI in Hayward filter rose to 32, SWG no flow light on. Help.
    -15,000 gallon vinyl liner in-ground pool
    -Pentair 1HP SuperFlo pump
    -Hayward Pro Series sand filter
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: No Flow on SWG Display
    Welcome to TFP!
    It sounds like your filter is so clogged with junk that the pump isn't moving enough water anymore. You need to clean your filter! Do you know how to do that? If not, tell us what kind of filter (model number) you have and we can help.
    Running a Hayward Swim Clear Cartidge Filter, Model C3020
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Here you go:
    http://www.hayward-pool.com/pdf/manuals/Manual97.pdf
    You really need to clean the cartridge filter.
    Thank u.
