Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Muratic Acid Cost
    SW Georgia
    300
    Muratic Acid Cost
    I was buying my Muratic Acid from Home Depot for around $9.00 per gallon last year. I when back last week to get some more and it was $12.00 per gallon. Has any body else noticed this? Is there something going on in the Muratic Acid market or did Home Depot just raise prices?
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    Jan 2011
    Richmond, Texas
    595
    Re: Muratic Acid Cost
    I get if for like 5 bucks a gallon at the grocery store. I think my homedepot was high too.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    Jun 2011
    Long Beach, CA
    2,790
    My local pool store sells it for $4.50 a gallon. Lowes and HD down the street are right about what you paid.
    Jul 2011
    St. Paul, MN
    244
    I get it for $3.50-$4.00 per gallon at Menards.
    20'x40' Oval 27,000 gallon Vinyl IG, Coverstar Auto Cover
    Hayward MaxFlo SP2303VSP, Sta-Rite PLD50 30 sq. ft. DE filter
    Rheem 266,000 btu natural gas heater
    Dolphin Nautilus Plus with Clever Clean
    TF-100 testkit w/ Speed Stir
    Jul 2011
    phoenix
    133
    my HD and Lowes sells it for about $10 per box (2 one gallon jugs in box)
    13k IG pebble pool w/waterfall, 1hp whisperflow pump, pentair ccp320 cartridge filter
    Circupool SI45+ swg
    TF100 +speed stir Taylor 1766 salt test
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Lowes near me sells gallons for $6.98 USD each. I double checked that price online to confirm my recall. Lowes also gives us 10% Military discount for the asking (and upon showing ID card).
    Aug 2011
    Texas
    45
    I've paying ~$12 for the 2 gal box at lowes.
    12k gal gunite, Sunstone Plaster, Pentair IntelliFloŽ VS+SVRS Variable Speed Pump, Pentair Intellichlor IC-40, Pentair CCP520 cart filter
    Aug 2007
    near the swamp
    806
    $5.49gl here 31.5%
    Nov 2011
    Magnolia Texas
    80
    $10.00 for a box of two gallons plus tax at my local Home Depot
    28,000 gallon salt water pool
    DE Filter
    Inground plaster construction
    1-1/4 hp pump with 1hp booster pump
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    jasonknox,
    Think you may have gotten your numbers wrong. I went to Home Depot last week and bought 2 gallons for $12.98. They come in a 2-pak. If you bought one gallon, my guess is they charged you for the 2-pak. They only sell them in 2-paks here in MD.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Jun 2008
    Marana, AZ
    347
    Last I knew, $9.99 for a 2 gallon box at Lowes and HD here.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Jul 2011
    Las Vegas, NV
    37
    In my area, Lowes will sell you two different containers of MA, depending on which part of the store you get it from. If you go in the paint area, you can find a gallon of Klean-Strip MA at 31% strength for about $7. (Don't confuse that with the Klean-Strip Safer, which will probably be right next to it). Or, you can go into the outdoor/pool section, and find Kem-Tek MA in a box, 2 gallons of 15% MA for about $10. That is, double the volume of half the strength for more money than a gallon of the full-strength stuff. And, if you want to smile, you can look at the contents of the "Daily Sanitizer and Shock" - 5.25% sodium hypochlorite, for $4.00 a gallon.
    Stay out of the "pool" areas of the hardware store, unless you're getting CYA.
    33k in-ground plaster pool and spa / Goldline T-15 SWG w/ Aqualogic controller / RS2000 Hayward pump / Pentair Clean & Clear Plus 420 sq. ft. cartridge filter
    38,475
    This is one thing I actually buy at Leslie's pool store since I believe it is twice as strong as that sold in the hardware store pool section. Although I do not recall the price.
    Just wanted to point out there is a large difference in strength sometimes do have to be careful doing price comparisons.
    Edit: just saw the last post basically said the same thing.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Nov 2011
    Magnolia Texas
    80
    Home Depot is 31.45% acid solution which seems to be standard and is about the max you can have.
    DE Filter
    SW Georgia
    300
    Quote Originally Posted by XsAllOverIt
    jasonknox,
    Your right, the prices I quoted were for 2 gallon packs. However they still went up $3.00 per two gallon pack.
    Dec 2010
    560
    If you're in the construction industry (which I'm not, but am fully aware), ALMOST all building materials have gone up at least 20% in the last 6 months. They say it's primarily due to the shipping costs, but everything has gone up. I've got a friend building a house and most of the materials that they had been quoted prior to building went up at least 20%. My guess is that would be the same reason for the muriatic acid.
    TFT-100 test kit
    Quote Originally Posted by faby3003
    Same here, I believe it was on sale last year around $3/gal and I bought 4. Haven't needed more since.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    May 2011
    Coral Springs, FL (near Ft. Lauderdale)
    93
    Prices went up in SE Florida as well. Last year, 2 gal box of 31.45% from the pool section of Home Depot was $9.98. It is now $11.98. Should check my local Leslie's/Pinch-a-Penny.
    15x30 inground concrete pool w/spa and spillover, all under screen enclosure
    Hayward C1200 StarClear Plus Cartridge Filter and Hayward Navigator V-Flex
    Jandy AquaPure 1400, Laars LX400 propane heater w/120 gal above-ground tank
    Jandy VS FloPro 2.7 HP Pump VSFHP270JEP; FlowVis FV-C Flow Meter
    Jandy iAquaLink and OneTouch controller w/PDA remotes; JVA for draining pool
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I get 29% at a local Paddock pool store for 2 gal box $12.95.
    chiefwej
  20. Back To Top    #20
    Dec 2011
    Murfreesboro, TN
    111
    My local Lowes charges $7.50/gal of 31.5% MA. I found an old fashioned hardware store that sells it for $5.25. I immediately purchased a case of 4-gallons. You have to ask the clerk for it because it's kept in the back warehouse. Don't assume they don't have it just cause you can't see it.
    Two days after I discovered the hardware store I found a similar store nearby that has MA for $4.50/gal. That's where I'll be getting my next case. If feels good to get a great deal and support a local mom & pop operation.
    I must admit feeling a bit wierd purchasing large amounts of MA in bulk from country style hardware stores. I get the strangest looks sometimes even after I tell them it's for a swimming pool. Next time I go I'll ask them to ring me up for several hundred pounds of fertilizer too, just to see their reaction ...
    22 x 36 In Ground Vinyl - 23K Gal - Saltwater - Tara Liner
    1hp 2-speed Hayward Super Pump, Hayward 6060 Booster Pump
    Hayward SwimClear C3030 Filter, Hayward 400Btu NG Heater
    Hayward Aqualogic PS-4, Polaris 280 Cleaner, ColorLogic 4.0 LED
