Thread: CYA Measurement not valid in dirty water.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    I mentioned this in my "Algae Diary" post, but I thought it deserved some attention on its own. I opened with algae this year, and my first water test showed a dramatic decrease in TA, but CYA was at about the level of last summer, 35ppm. This puzzled me because if the TA had dropped, that indicated major dilution from rainwater over the winter, but CYA should have been affected the same way.
    Now that the water is clear, I retested the CYA and found it to be less than 20. I had suspected that the presence of the algae and dirt from the winter had affected the CYA turbidity test. Waterbear felt that this was the case as well. Apparently that is confirmed. Interestingly, the pool water without the CYA reagent seemed very clear in the CYA test tube, with the dot clearly visible and sharp, even when the tube was full.
    Mar 2007
    San Rafael, CA USA
    12,082
    Perhaps the melamine in the CYA test precipitates more than just the CYA but also something in the algae. Also, the test is buffered to low pH so perhaps that has some effect. At any rate, it's good to know to measure the CYA when the pool is free from algae (i.e. has no FC demand overnight and no CC).
    gonefishin's Avatar
    Joliet, Il.
    413
    Re: CYA Measurement not valid in dirty water.
    Quote Originally Posted by JohnT
    I had to read your post a few times before I could agree with what you were saying. I was reading your your question to read that the measurement of CYA that you have is of no concern in dirty water.
    It took me three reads before I read it correctly.
    boy do I feel silly,
    dan
    33' Aqua-Leader AGP
    Hayward cartridge filter and IntelliFlo VS pump.
    Solar Heat coming ; used to own Aqua-Cal HeatWave 100k (HeatPump)
    Aqua-Rite t-15 SWG
    Guest
    The presence of algae or any other substance that can cloud the water can interfere with the CYA test since it is a turbidity test (you are measuring how cloudy the water gets). The effect of the cloudiness from the test and the initial cloudiness of the water are cumulative, even if the water looks clear before you add the test reagent. We use a colorimeter at work and if the water has algae the colorimeter will register it even though the sample tube looks totally clear! I have had many instances where I could not get a baseline reading when there was algae present and the colorimeter would not calibrate even though the sample looked clear to the eye.
    ktdave's Avatar
    Katy, TX
    888
    waterbear,
    If CYA is a turbidity test, could a turbidity meter (which gives readings in Nephelometric units, or NTUs) somehow be used to conduct a CYA test? The reason I ask is because I do groundwater sampling for work and we use a turbidity meter to test the turbidity of the water as we sample.
    Just curious.
    Dave
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    Guest
    If you could calibrate it to read the CYA concentration based on the turbidity of the sample it would work. This is how many of the electornic testers work but they are calibrated to read ppm CYA.
