Results 1 to 20 of 20
Thread: Where do you store your muriatic acid?
    May 2012
    Dallas, Texas
    18
    Okay so I'm in Texas and obviously it gets down right sweltering here in the summer. So where do you store muriatic acid that's safe for you and keeps the chemical in safe temperature climate? I honestly don't have any problem with the idea of just leaving the stuff outside, but I'm pretty sure it would build up some gases in the container before long right?
    10,000 gallons, In ground, Gunnite pool
    Pentair Whisper Flo Cartridge filter system with inline 3" tablet chlorinator
    Using the BBB method
    Mar 2010
    Spring, TX
    1,082
    Re: Where do you store your muriatic acid?
    I have a 4 shelf plastic cabinet outside close to the pool where I keep mine. I also keep it in the garage as well. You are not supposed to store it in living quarters or I remember reading this.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Jul 2011
    St. Paul, MN
    244
    I keep mine in the garage, but it doesn't get as warm here in MN as it does in Texas.
    You want to make sure you don't store it next to your bleach. I would think keeping it outside would be finel. I don't think acid is temperature sensitive like bleach is.
    20'x40' Oval 27,000 gallon Vinyl IG, Coverstar Auto Cover
    Hayward MaxFlo SP2303VSP, Sta-Rite PLD50 30 sq. ft. DE filter
    Rheem 266,000 btu natural gas heater
    Dolphin Nautilus Plus with Clever Clean
    TF-100 testkit w/ Speed Stir
    May 2012
    Dallas, Texas
    18
    I figure I can store my bleach in the washroom since I have an extra cabinet in there for storage. I just really don't want the muriatic acid in the house if at all possible. An outside storage unit may not be a bad way to go though. I'm pretty sure outside in the shade has got to be cooler than the enclosed garage come mid-summer. What about a plastic ice chest with the water drain hole opened up for venting or I could even add a few more holes on the side for venting? Just thinking that might keep it well shaded, insulated and away from accidental human tampering.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I just leave mine outside near the pool equipment. MA is stable at high temps, and the caps are vented so they won't build up pressure because of the heat.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    578
    I keep ours in the well house on the bottom rack of a storage shelf along with the DE and a measuring cup and a 2 gal pitcher.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Apr 2010
    Buckeye, AZ 85326
    619
    Quote Originally Posted by Melt In The Sun
    Ditto!
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    May 2012
    Dallas, Texas
    18
    then it sounds like outside by the pool it is. Thanks!
    Jul 2011
    Las Vegas, NV
    37
    The caps may be vented, but don't they have the plastic/metallic seal over the opening?
    33k in-ground plaster pool and spa / Goldline T-15 SWG w/ Aqualogic controller / RS2000 Hayward pump / Pentair Clean & Clear Plus 420 sq. ft. cartridge filter
    Oct 2009
    3,899
    Yeah that's true...mine stay in the garage until I need them, and I only leave them outside once they've been opened.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    My main concern is to make sure chemicals are safely located where kids, pets, etc. could not accidentially get to them.
    May 2012
    Dallas, Texas
    18
    Yeah hubby and I were talking about it last night. I do think we'll get some sort of vented storage (even if it's just something I built) that we can lock. We don't have pets, but that doesn't mean there isn't the occasional stray cat or squirrels or whatever in the yard and then there's always the concern about the kids even though they should never ever be in the area. The pool equipment is in a separate side yard area from the pool and the rest of the yard.
    Oscare66's Avatar
    Jun 2014
    Houston/texas
    1
    Quote Originally Posted by jotting View Post
    HCL boils at 230F so its ok to store outside. Hope this helps.
    May 2016
    San Antonio, TX
    7
    I just used it last night, for the first time, and it is nasty stuff!!! Based on what I'm reading here, mine is going outside.
    16K gal IG w/ SPA, Wet edge technology pebble plaster, pentair Intelliflo variable speed pump, Pentair Tagelus High Rate Sand filter, Pentair easy touch control system, Pentair Kreepy Krauly Legend cleaning robot
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    Be aware that the fumes which leak out through the cap will corrode anything metal. I use to store mine in the shed until I noticed the metal shelves near them started to corrode. Fortunately the power equipment in the shed wasn't damaged (yet). So I put the MA bottles in a plastic garbage can with a lid and located it outside the shed in the shade.
    I would not store it anywhere equipment/vehicles could be damaged by the fumes.
    PS - Jotting, I sent you a PM that may be helpful.
    PPS - Oops....I just noticed the date on the original post....oh well...lol.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    JoyfulNoise's Avatar
    May 2015
    13,250
    Agreed, too potentially dangerous to be indoors. I previously would store it in my garage with the caps sealed with black PVC pipe wrap tape and double bagged in heavy plastic. To annoying and I noticed a metal shelf nearby with some mild pitting corrosion. I decided I'd rather deal with hot swollen bottles outside then potentially risk damage inside. So now the entire 4-up of refillable jugs are stored outside in a back corner of my property where no one goes. Someday I'll get one of those resin Suncast sheds and store stuff in there
    Matt
    Oct 2010
    michigan
    284
    Store mine in the garage top shelf, never had a problem, still alive.
    Never smelt anything in the garage, otherwise would store somewhere else.
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    I never noticed any smell in the shed, but it still damaged the metal shelves.
    I didn't see anything like this in Pool School, so I hope it's ok to post this link to another site that has a great thread about handling/storing MA.
    Using Muriatic Acid to Safely Lower Your Pool's pH
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Resin deck box with a solo cup I re-use to add.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
  20. Back To Top    #20
    Apr 2015
    Pasadena, CA
    56
    Yes on storing outside. I keep mine in a plastic deck box by the pool with a lock on it. I don't want the kids to get in it, or the numerous critters that seem to love our property.
    22,000 gallon IG plaster pool, raised spa w/spillover, variable speed EcoStar pump, natural gas heater, 60 SF DE filter, SWG (all Hayward), AquaLogic automated controller, Kreepy Krawly, TF-100 Test Kit
