Thread: Jandy Aqualink RS problem - Shuting down
    Apr 2012
    Tampa, FL
    8
    I have a complete Jandy setup with an Aquapure. Recently on my PDA i get a fault that says 'General Fault' ' Check Aquapure'. Now I know that I have to go to the Aqualink RS box and remove the two screws at the top and check the panel behind to view the error. Problem is everytime I do that the entire system shuts down. Is there some type of safety I don't know about. All I am doing is removing the screws and tilting the panel out to view behind it, as soon as it looses power I have to fix the date/time again and still cannot see what error is being thrown. Anyone dealt with this before?
    16500 PebbleTec Pool in Tampa, FL. Jandy Aqualink with automation and PDA, Jandy PlusHP 1.5 HP motor (PHPM1.5), Jandy DE Filter (DEL48), Aquapure 1400 Chlorine Generator, Solar, Jandy Lite2 Propane Heater, Keepy Krauly Great White
    South Central NJ
    3,192
    Re: Jandy Aqualink RS problem - Shuting down
    The power issue requires removing the big panel to see the breakers, relays, and transformer. I suspect a loose wire at the transformer or the breaker feeding it.
    As for the cell, how old is it?
    What is your chem levels? Please include salt.
    When was the cell last inspected for calcium and erosion?
    Scott
    Owner of - PoolGuyNJ LLC
    On the backside of your aqualink board there is a transformer connection that may be loosely connected or may have a loose wire like what PoolGuy said.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Quote Originally Posted by knightsae
    what everyone else said...
    Oh, and, change your 9v battery, and you wont have to re-set the time and date.
    Factory Warranty Station for:
