Thread: Water Sudden Cloudy After Vacuuming?
    Glock30's Avatar
    Apr 2012
    Massachusetts, USA
    90
    Yesterday I finally was able to spend some time on my new pool.
    Full vaccum
    Brushed walls
    Cleaned filter
    Added salt (600 lbs. to start)
    Began SWG Programming (clock etc)
    Restart pump
    After I vacuumed the water seemed to get cloudy.
    I am fairly certain this was before I disassembled the filter.
    The filter was not loaded with debris, I cleaned it just to get a fresh start.
    It is possible that when I get home it will be clear.
    Is this normal after a vac?
    18' X 36' Inground Pool 26,000 gallons. SuperMax 27mil/27mil Vinyl Liner-Installed Fall 2011
    Pentair Intellipro Programable Pump (Model 011018) // Pentair S8M 500 Cartridge Filter // Circupool RJ45 Salt Chlorinator
    2 Hayward Skimmers // 3 Returns // 2 Savi Melody Pool lights // TF-100 Test Kit.
    poolsupplysales's Avatar
    Jan 2012
    Tulare, CA
    112
    Re: Water Sudden Cloudy After Vacuuming?
    It sounds like you have a bad cartridge in your filter check for any cracks or holes in the filter. when you vacuum up the dirt the filter is not holding it
    Glock30's Avatar
    Apr 2012
    Massachusetts, USA
    90
    Hmmm. Could be.
    It was new from the factory and never removed until after I vacuumed.
    Water was crystal clear before vacuuming and filter appeared to be working perfectly.
    Vacuuming can stir up dust that was on the bottom and cause some temporary cloudiness. If it isn't all better by the time you get home there may be something more complex going on, but odds are it will be all cleared up. That doesn't mean that poolsupplysales is wrong. A damaged filter would always stir up a fair bit of dust when vacuuming. A working filter can still stir up some dust, but not as much and not as likely.
    Glock30's Avatar
    Apr 2012
    Massachusetts, USA
    90
    Thanks to both!
    Glock30's Avatar
    Apr 2012
    Massachusetts, USA
    90
    Water was clear when I got home!
    Thanks for enduring my paranoia. :P
