Thread: Adding Dry Chemicals
    Mar 2012
    London, ON CDN
    42
    I have a beginner question here. When using the pool calculator the chemicals to be added to the water are measured in grams. Just wondering how you guys added chemicals by weigh? What type of measuring device are you using; I guess is what I am asking.
    I have a measuring cup but "cups" are a measurement by volume, not weight, so I am confused about how to add chemicals accurately by weight?
    21K gal, Vinyl, 16X32, 3/4 HP Hayward Maxflo, Hayward Pro 24" Sand Filter
    Apollo Pools (Canadian Supplier for Taylor Kits) www.piscines-apollo.com
    Re: Adding Dry Chemicals
    The Pool Calculator will also give you amounts by volume. The results aren't quite as precise, but they are still good enough.
    For larger quantities I go by what fraction of the entire box/bucket I need. Say I need 2 lbs of something coming from an 8 lb bucket. That is 1/4 of the bucket. Then I simply judge the 1/4 bucket by eye.
    Mar 2012
    London, ON CDN
    42
    I was thinking this would be the answer. Thanks for confirming that for me Jason.
