Thread: My Sand filter seems to be leaking from bolt on bottom......
    hawkeye's Avatar
    davenport,iowa
    118
    Does anyone know if this is a easy fix? seems water is dripping out of hole bolt goes through that mounts tank to base..the bolt is rusty as **** as well....thanks
    18ft 52in deep doughboy 8000 gallons
    22 in sand filter
    1 1/2 pump
    tk-2006 test kit that rocks!
    12.5% chlorine
    aqua critter vac
    22,542
    Re: My Sand filter seems to be leaking from bolt on bottom..
    While it may help to know the brand of filter you have, it's most likely not something you even want to try and fix. If it's truely leaking from a mounting bolt hole (extremely rare) the vessel has been comprimised and you shouldn't try to repair it. I'd do a careful inpsection to make sure it isn't leaking somewhere else and running down there.
