Thread: Suggestions on these readings
    Aug 2011
    Augusta, Kansas
    88
    I've finally got my CYA up and FC up (now too much). Suggestions on what I should go for next to adjust. We are officially opened as my son and a friend spent all Saturday (it was 91 out ) in our (IMO) cold but beautifully clean and clear pool
    FC 11
    CC 1
    TC 12
    TA 140
    CH 230
    CYA 50 (though my 10 yr old who loves to help play chemist says that he could see the dot and 40 was better in his opinion)
    ph - 8
    I've put the swg down from 9 hrs to 7 hrs. Forecast this week is mid-high 70's.
    Diane
    Diane
    15,000 salty gallons - 24' x 12' x 52" Intex Ultra Frame Pool
    Intex Sand Filter, Pump, SWG - TF-100 and speed stir
    Re: Suggestions on these readings
    You want to keep the FC level higher than normal, ideally you should go to shock level, because CC is higher than 0.5. Once CC comes down you can go back to normal chlorine levels.
    Your PH and TA are both a little high.You want to keep PH at 7.8 or lower, and work TA down to below 90. Lowering PH to 7.2 every time it gets to 7.8 will work the TA down over time.
    For use with a SWG we recommend keeping CYA between 70 and 80.
    Feb 2008
    Denton, TX
    5,061
    Keep the FC up until your CC is 0.5 ppm or less and you lose no more than 1 ppm FC overnight. Then you can address the other levels.
    Butterfly's Avatar
    South Carolina
    10,045
    Lower the pH first. Then shock to get rid of the CC.
    You're done SLAMing when:
