Results 1 to 9 of 9
Thread: is cya my problem
    Jul 2011
    Terre Haute indiana
    60
    is cya my problem
    my fc 5.5, cc 0, tc 5.5 al 140, ph between 7.5 7.8, ch 250, and cya 30. I get my fc up to 6 at night and next morning its still six maybe 5.5 but by noon its down to 2 i bring it back up to 6 and by 4 pm its down to 2 again. is this normal or should i raise the cya. Also this is my first year starting with bbb after finishing the last 30 days of the last season, never has it opened this easy and the water clear up this fast, thanks to all
    19500 gal, IG, haywood s-200 sand filter & pump, 3/4 horse single speed motor, vinyl liner, tf 100 test kit, installed early 80's, Terre haute,In
    Butterfly's Avatar
    South Carolina
    10,045
    Re: is cya my problem
    Yep, looks like you need to up your CYA to maybe around 50ish.
    Is your pool in full sun?
    You're done SLAMing when:
    Jul 2011
    Terre Haute indiana
    60
    yeah it gets full sun from about 10am to 4:30-5
    Apr 2011
    Lynchburg VA
    393
    Mine get full sun most of the day and I like to run my CYA at about 55.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Jul 2011
    Terre Haute indiana
    60
    i have 3 inch triclor tabs left from last year, what do you think about using them to get the cya up seeing how my ta is high. thought the tabs would raise cya and lower the ta. if so how many would i need to go from a cya of 30 to 50
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by REBARBEE
    It would be a slower process to raise the CYA this way. You can use the PoolCalculator.Com to calculate the amount needed to do what you want.
    Jul 2011
    Terre Haute indiana
    60
    thanks. think i go to walmart
    22,551
    I for one would use the tablets since you already have them. It's not like you have to be in a hurry raising the CYA or lowering the TA. Or are you???
    Jul 2011
    Terre Haute indiana
    60
    no hurry at all. cant remember it looking this good
