Thread: Liquid Acid
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Liquid Acid
    Is miratic acid heavier than water?
    Thanks
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    Yes, muriatic acid is denser (heavier) than water. With some mixing/circulation going it will mix with the water quickly enough that that doesn't really matter. But in still water it will tend to sink to the bottom and puddle there for a while before it finishes mixing.
    30,431
    Good question. I didn't know HOW much heavier so I googled it and found something interesting......It's apparently an in-stock item at many Tractor Supply Stores....$4.98/gal...I've paid 7.90 @ Lowe's if I remember correctly.
    (BTW, Specific Gravity is 1.16 @ 68 degrees f.)
    Mar 2008
    Wake Forest, NC
    128
    looks like i am going to tractor supply in the morning. What was the name of the place you grt the 12.5% bleach?
    IG Vinyl liner, 21,500G sport bottom, TR-60 sand filter, 3/4 HP Whisper Flow, BBB with 12.5% Liquid Chlorine
    30,431
    PM'd you since it's a local store....not of interest to most
