Thread: Malfunctioning SWG?
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Malfunctioning SWG?
    My pool is new as of October-November 2011, so the SWG is still new (right?). Since I have an automatic cover, I've even been able to turn the SWG off at times when the Chlorine level is good or when I want to lower the level. Most of the time I'm running the pump 8 hours a day with the SWG at 10% or less.
    Yesterday the SWG read "oversalt" and the reading was supposedly 5600. Today I get the following readings:
    FC- 21 (brought up to shock level with Chlorox after my darling 2 year old grandson pooped in the pool yesterday <insert eye roll>SWG is off)
    CC- 0
    pH-7.6 (was 7.2 yesterday morning before pool party which assuredly raised it up)
    T/A-90
    CH-290
    CYA-50 (prob. a touch higher but not reading yet since I added a bit a few days ago. I feel safer running on the conservative lower side here since I do use the automatic cover and fear adding too much. Don't want to deal with *those* consequences)
    NA-3400 (a very consistent reading each and every time I test)
    Do you think the salt cell is malfunctioning or could I be causing it to malfunction when I turn it off-on, or put it into "winter mode" when I want less than 10% running?
    I'm looking for assistance here before my PB comes on Friday over a different issue, and of course the device is still under warranty.
    Thanks in advance!
    22,548
    Re: Malfunctioning SWG?
    Have you inspected it to see if it has any buildup on it? Have you cleaned it? I'd clean it before anything else.
