Results 1 to 13 of 13
Thread: how long do pumps last
    May 2008
    NE Florida
    51
    I'm about to change pumps or motors. I have a 2 hp superpump II that's running fine but want to make it more efficient. We've had the house for 7 years with never a problem with the pump/motor. The pump is 12 years old and runs year round in Fla. I'm about to put a new 2 speed motor in it to run it on low most of the time and save some $ on operation. I got to thinking about the age of the whole unit and am now wondering if perhaps I should just go with a total new pump. Do the wet ends tend to hold up for a long time on superpump II/s? switching out the motor would be the easiest, least expensive route, but I'd hate to see the wet end go in a year or so. I'm handy, so any rebuilding parts to install isn't a big deal if that will do.
    Thanks for your input.
    22K gallon free form pebble tec pool, non screened, surrounded by 3, 100+ year old Live Oaks (pure misery for 3 months every spring) elevated non heated spa, jandy cl340 filter, Pentair Inteliflo 3hp pump, Jandy 1400 swg, infloor cleaning system which has had all outlets removed due to uselessness of system with the organic load the pool carries and now low rp
    Sep 2011
    Atlanta Ga
    310
    Re: how long do pumps last
    I'm new here and don't have an answer to your question, but I do have a related question. How much is the power bill to run a pool pump? I have a 1 hp pump. I am in a new house so I don't know how much of my power bill is the pump, and how much the AC. I usually turn the pump off at night, but the pool is slightly clearer if I run the pump 24 hours, and I was told it is actually better for the life of the pump if you run it non stop. I need to know what the power bill is for running the pump in order to make a decision on how much I run it.
    36 x 18 oval pool, inground, plaster pool.
    27000 gallons
    1 hp pump. Sand filter
    Pool built in 1971.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    In my experience pump motor failure is the most common problem, however over time the plastic parts become brittle and prone to breaking (things like the hinge points for the filter cover plates), having said that I have seen them run for 10 years, or have a motor failure on an otherwise good pump after just 2 or 3 years.
    Ike
    p.s. as to cost of operation a lot is going to depend on your local electricity rates, and if you have variable rate mettering for off prime hours.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    As long as the wet end is holding up and there is no damage to it the wet end then yes changing just the motor is fine. Just remember make sure the impeller has no interference. 12 years is on the high side so your lucky and git your moneys worth! Unfortunately todays motors don't last as long as the ones from 10-15 years ago. Today 5-7 years is a good pump! Especially when it runs year round and is out in the elements. The constant running of a pump doesn't increase the life span of the pump, Tom. It needs a cool down cycle. Leaving electronic devices on like your TV prolongs it's life. Cycling power ON/OFF on electronics does more damage then the heat it is subjected to.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    May 2008
    NE Florida
    51
    Sounds like it's a coin toss with a 12 year old wet end. It runs everyday, but not all day long, if I gave you that impression.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,204
    Quote Originally Posted by TomAtlanta
    Allowing for some inefficency, a standard 1HP pump is going to run about 1KWH/Hour, so if your rate is $0.14 per KWH, about $1.12 for an 8 hour run.
    mas985's Avatar
    Pleasanton, CA
    11,769
    Not all 1 HP pumps are created equal and the power consumption can have a very large range depending on if the pump is up rated or full rated as well as the plumbing it goes on. But the typical range is 1.3 kw to 1.6 kw for an up rated 1 HP and 1.6 kw to 1.9 kw for a full rated 1 HP.
    Mark
    Sep 2011
    Atlanta Ga
    310
    How long do most people run their pumps every day?
    27000 gallons
    Pool built in 1971.
    It varies wildly, anywhere from an hour a day to 24 hours a day. The ideal pump run time depends on many factors and the only practical way to determine it is experimentally.
    Jun 2011
    Trenton, TX
    18
    Hi, beware of just replacing the motor. We have a five year old AO Smith BN50 motor and a Waterway Workhorse 1.5 hp pump, 2 speed. Pump refused to start, just hummed, ordered and got a replacement motor, exactly the same, only to find out the pump is obsolete and you can't buy the pump housing - a $30.00 plastic part! So, we have a new pump but can't attach it. We're still trying to find the part; it would have been much quicker, easier and cheaper in the long run to just buy a whole new pump with the filter basket attached, but now we're sitting here with a $200.00 new motor that we'll probably end up returning and starting over. Look up your motor and pump online, or if you're handy make sure everything but the motor is okay. When ours was taken apart, the bolts were rusted out and broke off still inside the pump housing; the whole motor actually came apart at the mount first, rusted through. If anyone reading this has the same motor or problem, post it!
    15' round AG Trevi, 1.5 hp Hayward Matrix Powerflo, 200 SF Waterway cartridge filter
    Sep 2011
    Atlanta Ga
    310
    Is the experiment basically to see by trial and error how many hours you need to run it to keep the water clear?
    27000 gallons
    Pool built in 1971.
    39,281
    Yup. The minimum run time is the amount of time required to get the pool as clean as you are happy with. The primary driver for run time is the filtration as adequate chemical mixing of the water generally happens in less time.
    Sep 2011
    Atlanta Ga
    310
    Thanks for the info. I guess the chemical mixing only takes an hour or two, correct?
    27000 gallons
    Pool built in 1971.
