Results 1 to 14 of 14
Thread: Pool Balanced but still have Green Algae
    Oct 2011
    Kingwood, Texas
    18
    I tested the pool on Friday - everything was all in balance. Why do I still get green algae on the north facing wall of my pool? I've cleaned my cartridge filter twice this month hoping that would help. I keep it brushed off as soon as I see it. I have natural rock that touches the water on that side of the pool. Could there be some sort of algae that is seeping out of the rocks? The green starts at the surface of the water then grows downward. Water is crystal clear and beautiful. I'm using the last of my tri-clor tablets then going to the bleach method.
    FC 2
    TC 2
    CC 0
    TA 130
    ph 7.8
    CYA 35
    CH 420
    Thanks!
    17,000 gal. inground pool, Diamond Brite cool blue, Kreepy Krauly Legend inground pool cleaner(w/seperate pump), Pentair Clean & Clear Plus cartridge filter (420sq.ft), Pentair IntelliFlo vs-3050 variable speed pump, Pentair Rainbow model 320 chlorine feeder, Pentair IntelliBrite 5g LED lights (2), waterfall and 32 ft. of weeping wall (w/seperate pump), 2 skimmers, 4 drains, tanning ledge w/2 geisers, Jandy EE2500TI Heat Pump
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Re: Pool Balanced but still have Green Algae
    To my inexperienced eye, I'd wager it's because you don't have enough chlorine to kill off existing algae.
    I suggest:
    Shock the pool according to the directions here.
    I'd also advise a higher post-shock FC level, in the 4-5 range, as suggested here.
    By all means, chime in experts if I've missed anything, or misled the OP!
    -Gordon
    Pool School helps me maintain my 13,500G 24' x 48" ASP with Sand Filtration using a TF100 Test Kit and Pool Calculator.
    Remember, the Shock Process should be followed until : 1. CC is less than 0.5 ppm, 2. An OCLT shows a loss of 1.0 ppm or less and, 3. The water is crystal clear.
    --I didn't buy my pool to swim in it. I bought my pool to watch my wife swim in it. :wink:
    22,551
    It's definitely because you don't have enough chlorine.
    Is it growing on the shady side of the pool? If so it's probably mustard algae.
    Is that an area of poor circulation?
    Have you ran an OCLT (see sig if you don't know what that is)?
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    I would question your test kit. If you have visible algae you have to have some CC? You shouldn't be able to pass a OCLT.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by maxepr1
    If you have visible algae you have to have some CC? .
    Not in my experience. I never see CC from algae.
    Oct 2011
    Kingwood, Texas
    18
    The instructions for shocking the pool says to add some chlorine until you reach the shock level (which according to the chart I am aiming for a 16). How much is "some?" Should I start with 1 gallon, 5 gallons? etc. I tried to use the pool calculator - entered the current FC at 2 and goal at 16, but when I hit the calculate button, nothing happens. I have searched the board looking for this answer but can't find a clue as to how much to start with. Help!
    My test kit is the leslies total poolcare DPD Test Kit. They didn't have the recommended one. I need to order it.
    Thanks!
    4 1/2 gallons of regular 6% bleach to raise FC from 2 to 16 in 17,000 gallons. Remember that none of the common jugs are exactly a gallon.
    Oct 2011
    Kingwood, Texas
    18
    Thank you! How did you figure that out?
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by momtaps
    Did you put your pool size in before you started?
    Oct 2011
    Kingwood, Texas
    18
    I had entered 17,000. When I removed the comma - 17000, it worked. Thanks so much for everyone's help.
    Oct 2011
    Kingwood, Texas
    18
    OK, I got my new test kit TF100 in the mail today and began the process of shocking my pool. According to the pool calculator, with today's test results, I needed to add 2.1 jugs of bleach to raise the FC from 5 to 16. I did this, waited an hour, and tested again. I am at 20.5 now! Is that OK? I am shocking because of algae.
    CYA 40
    FC 5 (before shocking with chlorox 6%)
    CC 0
    TC 5
    TA 80
    ph 7.5
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    That is fine. How sure are you of your pool volume?
    CYA 40
    CC 0
    TC 5
    TA 80
    ph 7.5
    The rest of you numbers look good! Have you measured CH yet?
    Oct 2011
    Kingwood, Texas
    18
    Just tested the ch - 3 times with 3 different results!
    Leslies kit - 410
    TF100 - 800 1st time, 650 2nd time
    What's up with that?
    22,551
    Are you using a speedstir? If not I'm not surprised at the variance. The CH test is very hard to do repeatedly by hand swirling.
