Thread: Savi Melody Pool Lights-Difficulty Changing Modes
    Glock30's Avatar
    Apr 2012
    Massachusetts, USA
    90
    All,
    Is it just me or do any other Savi Melody Pool Light owners have difficulty changing modes using the "on/off" switch method.
    I am not a stupid person, but I cannot what they are trying to tell me on that instruction card.
    Any step by step instruction help would be greatly appreciated.
    18' X 36' Inground Pool 26,000 gallons. SuperMax 27mil/27mil Vinyl Liner-Installed Fall 2011
    Pentair Intellipro Programable Pump (Model 011018) // Pentair S8M 500 Cartridge Filter // Circupool RJ45 Salt Chlorinator
    2 Hayward Skimmers // 3 Returns // 2 Savi Melody Pool lights // TF-100 Test Kit.
    Re: Savi Melody Pool Lights-Difficulty Changing Modes
    The wording is a bit awkward but the process isn't too bad once you get the hang of it. It's all based on how long the light is turned off for.
    If it's a quick off-on then it steps to the next pattern.
    If you leave them off for a little bit longer and then turn it back on, it resets to the default pattern.
    If you leave them off for a long time > 10 seconds. The when you turn it back on the pattern isn't changed from before.
    I don't know the exact number of seconds because I lost the instruction card.
    John
    Esther Williams 18'x33'x50" oval above ground
    190L Jacuzzi sand filter with 3/4 hp motor
    Pentair model 320 auto chlorine feeder
    Taylor TF-100 test kit
