Results 1 to 20 of 20
Thread: Northernn VA Leisure 38' Moroccan Install
    Dig was Saturday. Pool to be set today. More photos to follow...
    38' Leisure Moroccan (20K gallons)
    Pentair VS pump/EasyTouch w/ IC40/ Clean&Clear Plus/Robot cleaner
    3 Pal Treo LED lights with WIRTRAN remote
    N Virginia
    -Leisure Moroccan 38' Fiberglass
    -19,800 Gallons
    -Pentair EasyTouch 4 w/IC40 Chlorinator,VS3050 Pump, Clean&Clear Plus 320 Cartridge Filter,Prowler 720 Robot Cleaner
    -1 Skimmer/ 3 Returns/2 Drains/2" Piping
    -3 Fiberstar Pal Treo LED lights/Wirtran
    -TF100 TestKit
    Re: Northernn VA Leisure 38' Moroccan Install
    More Photos from Day 1
    img]http://i1152.photobucket.com/albums/p485/reubinthornton/IMG_2944.jpg[/img]
    mg]http://i1152.photobucket.com/albums/p485/reubinthornton/IMG_2979.jpg[/img]
    N Virginia
    -19,800 Gallons
    -TF100 TestKit
    Day 2, Pool Set, 1st hickup... Pal Treo lights don't fit the fittings... Was told lights fit "standard" 1 1/2" return... couldn't find one that fits from pool retailer, had to order fittings, won't be in till Wednesday.
    After hole prep was completed, took 2 hours or raising/lowering, adding/removing gravel to set pool.
    N Virginia
    -19,800 Gallons
    -TF100 TestKit
    Casey's Avatar
    SW PA
    10,163
    *sits with bikini on and towel by side in anticipation for a beautiful pool*
    Backfill and water began today. Couldn't finish filling. The Fiberstar lights (Pal Treo) for some dumb reason don't come with the niches to install them. Installation manual says 1 1/2" return fitting, NOT, had to order them seperate. Makes you wonder why you could buy them without the niches to start with... Another obstacle to be corrected unexpectantly is during excavating along the detached garage the power cable to garage was uncovered. It was only buried about 12"! Still have this one to overcome. I installed the EasyTouch panel. My PB is not familiar with the ET. The fun will begin when I try to interpret the setup manual.
    N Virginia
    -19,800 Gallons
    -TF100 TestKit
    Feb 2012
    Lancaster, PA
    112
    I love the setting, with that big beautiful tree in the background!
    16 x 32 vinyl In-ground Lagoon; Shallow pool 3' to 5'; Buddy Seat; IntelliBrite 5g LED; Pool Pilor Digital SWG, Pentair Clean & Clear Plus 320; Pentair Intelliflo VS + SVRS; Pentair Sand Shark. My Construction Thread - Spring 2012
    Quick update. Weather has delayed getting pump up and running. I finished the wiring Sunday (pump/IC40/Wirtan & Pal treo lights). All that's needed now is anchoring pump to pad and installing o-ring in piping that was missing. Hinesight... maybe should have gone with Pentair pool lights. Pentair lights are more that Pal Treo but convenience of being able to run lights with ET and cost of Wirtran would probably have equalled out. I'll post photos tomorrow when pump is running. Stamped Concrete work begins next week. Will include 5' around 3 sides of pool, patio along side of detached garage, 4' sidewalks connecting the 2 garages and deck off back of house, and 12x16 patio off of sunroom.
    N Virginia
    -19,800 Gallons
    -TF100 TestKit
    Getting closer.... concrete prep and pour. Ended up being 25 yards of stamped concrete. Turned out REALLY nice.
    N Virginia
    -19,800 Gallons
    -TF100 TestKit
    Sep 2009
    Frederick County, MD
    180
    We have the same pool. I hope your family enjoys it as much as we do. Install looks great so far.
    Jim
    Southern Frederick County, MD - Leisure Moroccan 38 Fiberglass Pool - 19,800 gallons
    Pentair 1.5 hp 2 speed pump - Cartridge filter - Dolphin robot - TF-100 Test Kit - SWCG
    Final photos below. Install completed in about 6 weeks.
    N Virginia
    -19,800 Gallons
    -TF100 TestKit
    Columbus Ohio
    178
    IT looks beautiful!!
    Purposed new pool at home being built- 20x40 vinyl pool, 20ft vinyl covered steps, Automatic cover, 6 ft sheer decent, 4 lighted deck jets, lime stone coping, easy touch, heat pump, SPA- 8x8 fiberglass shell, limestone steps surrounding
    previous home- 16 x 32 IG Vinyl- Install- Mid June 2011. 3ft Shallow 8ft Deep/ Totally Hayward 1HP pump/ 250 pound Sand/ AquaPro800 Heat pump/ Blue Hampton Liner/ 2 Intellibrite LED Lights/ Polaris 360/ 4 Deckjet II's/ 3ft concrete Apron/ 800 sq ft Paver Patio
    This is the exact pool I am considering, actually this size and the 33. I just started a new thread, as I am a complete newbie to this process and have never had a pool. Are you happy with this brand and the fiberglass in general?
    Can you give me an idea of the pool cost? I know there are plenty of extras so just the pool would be helpful. We have a budget of 25k and I am fearful we wont be able to make it for this pool in either size. Feel free to pm me if you don't want to put it in the forum.
    Thanks for your help. Yours cmemout great!
    Apr 2012
    northwest PA
    43
    looks beautiful! i like the concrete a lot. do you happen to know the colors used, and did they use any kind of no-slip additive or anything?
    Samantha Sabrina's Avatar
    Apr 2012
    Bloomsdale, Mo
    346
    That looks Wonderful!
    Awesome setting too.
    Nice to see a thread where a PB actually knows what they are doing, and man does it ever look like they take PRIDE in their work!
    Happy Swimming!
    Samantha
    In the process of building for a 22' Intex Ultra Frame, (completion date up in the air at this point).
    We could not beat our backyard into submission so we "Buried It".
    The color added to the concrete was a beige. The wash was black and sealer clear. There is no non-slip added. PB did not recommend non-slip and I didn't want it to start with; too rough on the feet. I'm enforcing the "no run" rule to prevent slipping. Honestly, it's not that bad.
    N Virginia
    -19,800 Gallons
    -TF100 TestKit
    Quote Originally Posted by Meth
    I planned for a year and researched EVERYTHING. The shell alone cost $18k (delivered). I initially made a deal with an internet company to supply and install the pool. When I got to the day before delivery I discovered I was about to get screwed. The contract was cancelled but I was left with the option of going to court to try to get my deposit/pool price ($18K) back or accepting the pool and finding a local installer. As usual, when trying to save money, if the deal sounds too good to be true...it's because it IS too good to be true.
    I saved money where I could, e.g. bought the Pentair components off the net (big savings), I did the electrical work, prep and sod laying, etc. I kept all receipts and invoices throughout process. I "thought" I could get this done for $35K. But, I decided to NOT cut corners and go all out with the concrete, sidewalks, additional patio off sunroom, etc. Ended up pouring 25 yards of concrete. During the planning phase I changed and added concrete 3 times. I just kept telling myself that if I was going to do it, NOW was the time to do it. About the most common regret I've read on this site from home owners is NOT building enough patio/concrete. So, while I was being frugal, I was driven more by not wanting regrets at the end of the install. Hidden costs to beware of are in things as simple as backfill...some builders go with sand or 57 gravel (both are inexpensive). My PB insisted on #8 gravel. It took 60 tons of gravel. Gravel cost direct from quarry was $3k. I don't have regrets... I still have to install a fence (bought a used Jerico 48", black aluminum off Craigslist). When the fence is installed, I'll be right at $48K TOTAL.
    I read many posts about FB pools having spider cracks, minor flaws, etc. When I received the pool I couldn't find anything wrong. And, after install, I still have zero issues with the pool. In hindsight, I go with the very same pool again, no reservations.
    N Virginia
    -19,800 Gallons
    -TF100 TestKit
    Yukon Jack's Avatar
    May 2011
    Rose Hill, KS
    94
    Sure looks great - bet your enjoying it!
    18x33 AGP, 17,300 gal, Hayward Sand Filter, 1.5 HP 2 Speed Hayward Pump
    Apr 2012
    northwest PA
    43
    [quote="Gunnert"]The color added to the concrete was a beige. The wash was black and sealer clear. There is no non-slip added. PB did not recommend non-slip and I didn't want it to start with; too rough on the feet. I'm enforcing the "no run" rule to prevent slipping. Honestly, it's not that bad.
    thank you for the info. i think it's very interesting (and concerning!) to read about everyone's slippery or non-slippery stamped concrete. i have a few weeks to figure out exactly how i'm having the concrete done, so i am trying to get as many opinions as possible as i'm nervous about it ending up slippery.
    I'd be more concerned with raw feet and scuffed knees than slipping on the patio... just my .02...
    N Virginia
    -19,800 Gallons
    -TF100 TestKit
  20. Back To Top    #20
    Aug 2010
    Cincinnati, OHIO
    17
    Quote Originally Posted by Gunnert
    I'm considering a Leisure pool as well, thanks for the thread on your journey. Looks great!
    60 tons of #8 was $3k?!
    Hydraulically mundane 20x40 rectangular polymer (~30K gal.), IntelliFlo VS+SVRS pump, IntelliChlor IC40 SWCG, Pentair CCP520 cartridge filter, LED light, 2xDeck Jets, SR Smith Turbo Twister slide
