Thread: 1st Test After Installation
    Crazycalvin's Avatar
    Mar 2008
    Irmo, South Carolina
    56
    Hello, I just got back from getting my water tested at the pool store. The results are as follows:
    Water Temp: 62Degrees F
    Saturation Index: -2.1
    TDS:100
    CYA:0
    Total Chlorine:0.2
    Free Chlorine:0
    pH:6.7
    Total Alkalinity:27
    Adjusted Total Alkalinity:27
    Total Hardness:59
    Optimizer +: 7 ( Don't know what this is)
    We have an AGP 15 x 26 x 52 with 200 sq. ft. Cartridge filter, 2.5 HP DS Pump. So My next question is where to go from here. Thanks in advance, Calvin.
    15 x 26 Sharkline
    2.5 HP Dual Speed Pump
    200 Sq. Ft. cartridge filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Your pool would probably hold about 11,500 gallons
    Chlorine first. 300oz of 6% bleach will get you to shock level. Hold it there for a day or two, which might take some effort since you don't have any CYA.
    Get about 2lbs of CYA in an old sock hung in front of a return. It may take as long as a week to dissolve.
    Add 21oz by volume of washing soda or 46oz by volume of borax to get your pH moving up
    You'll also want to add some baking soda soon to raise your TA.
    All of these amounts can be figured from Jason's pool calculator at poolcalculator.com.
    The most important thing to do is to get a good test kit. A Taylor K2006 is fine, but you can buy one from Duraleigh at TFTestkits.com that is a good one and you can get testing help from him on here.
    When you add chemicals, plan to undershoot by a fair margin so you don't end up going back and forth from too low to too high.
    I agree with everything JohnT said.
    Optimizer Plus is borates.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Crazy, welcome to TFP (your name has mine beat in terms of 'lack of trust' when giving advice )
    John is giving you good advice! I'd say take care of the chlorine and pH first!!! They can be done at the same time. If you go with the 'washing soda' it will also bring up the TA (at pool stores it's called pH up or soda ash). From your posted #s - the only chlorine you have in the pool is combined, and therefore can't do 'diddley' to sanitize the pool - so defenatly get some good chlorine in ASAP. The low pH is harming the liner so, again - get that up over 7.0 ASAP!
    We'll get you to a 'trouble free pool' - just stick with us!
    [Getting a GOOD test kit will help you in more ways than I can describe!!! - Look at the TF- 100 or ask us and we'll point you towards a good kit so you can do your own testing (the #s you give 'smack' of a pool store's results - your own tests would be better)]
    Luv& Luk
    -Ted
    Mar 2008
    56
    Thanks for all of the answers. I am gathering up the chemicals now and getting ready to set the plan into action. I will let you know how things turn out and ask any questions, if I have them. Thanks again, Calvin.
    15 x 26 Sharkline
