Thread: Finish new swg setup
    Apr 2012
    Latrobe, Pa
    11
    Today I finished the setup of my equipment deck, sand filter and pump, solar bypass manifold, and swg. Im sure this has been discussed before but what is the differance between pool salt and solar salt and which is preferred. Also ive read that the copper ion should be unplugged for reasons but has anyone had any adverse affects who chose to leave it connected. Any help is appreciated.
    Intex 14' x 42". 3557 Gallons, 1600 GPH Intex Sand Filter, Intex CS8110 Swg Post 2009, 2x20 SunHeater Panel.
    Custom Built Equipment Deck, Small Fountain, Intex LED Light, Custom Built Manifold.
    Re: Finish new swg setup
    Pool salt is ground more finely than solar salt, otherwise they are identical. Both are totally fine to use, as the salt dissolves very quickly either way. Solar salt tends to be less expensive. You want 99.6+% pure salt, without any additives (avoid rust fighter for example).
    Apr 2012
    Latrobe, Pa
    11
    Okay thank you
    Apr 2012
    Latrobe, Pa
    11
    Here are some pics of the project i just finished. any comments are appreciated
    http://s1249.photobucket.com/albums/hh5 ... sup201178/
