Thread: Perimeter Drains clogged
    Hi,
    We just bought a house with an inground 36 X 16 pool. Opened it not too long ago, and while cleaning the patio(which is exposed aggregate) around the pool found that the drains did not drain. Tried a plumbers snake and only got down a couple feet. We have a A LOT of pine needles, bugs and **** that accumulate in the area. Does anyone know a good way to fix this by yourself, or am I calling a plumber?
    Thanks
    BL
    Re: Perimeter Drains clogged
    I suggest getting a drain king, or similar fitting that seals a garden hose to a PVC pipe, putting it in the intake pipe inside the skimmer, and adjusting the valves (or plugging lines) to for the water to only come back through the clogged drain. It doesn't always work, but is certainly worth trying. Often running water the opposite direction like that clears the debris right out.
    22,553
    If you're meaning the deck drains, the snake is probably your best bet. If the outfall end is open you can use the snake inserted into it and see if it'll clear that way. If it's not I'd suggest just staying at it from the grate end. Beyond that, it's probably plumber time.
