Thread: Hayward Inground Pool Light
    I have a hayward pool light for my gunite 20x40 pool which is not working.
    The pool light is connected to a junction box installed in the deck at the head of the pool. The entire junction box is installed in a vinyl container set in the concrete. Both the feeder line and the pool light line come up from conduits set in the concrete.
    Now when I connect the light to a extension cord it comes on. The circuit up to the pool light switch (about 50ft) away is good, So I assume I have a fault in the line between the switch an the junction box. The problem is I have no idea how the cable between the junction box and switch is laid so I do not know how to trace the cable and localize the fault
    Anyone resolve a similar issue? What are my options? Can the cable be pulled or do I have to cut the deck?
    Thank you
    Apr 2011
    Lynchburg VA
    393
    Re: Hayward Inground Poool Light
    Can you attach new lines to the old lines and pull them through? I am no electrician but can you use a continuity tester on the lines to figure out how it is wired?
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    22,542
    Can you post a pic of it?
    If I understand correctly, the power runs from the power panel to the switch, then from the switch to the junction box in the decking, then from there to the light. You have power to the switch, and if you apply power to the light at the junction box it works?
    It should be ran in conduit and Ross has the right idea if it is.
    Ross: How will a continuity tester show me where the problem is?
    Here are pics of the unit
