Thread: Super Chlorinate Pool Ratio to Gallons ?
    If i have a 10K Gallon Pool and I get my pH and Alkalnity to the correct levels, how much is the recommended amount to super chlorinate the pool when opening the pool ? Alos, is there any risk to dumping too much chlorine in and if so, how much is too much ? Thanks
    Scott
    sbelgrave @ Westminster, MD
    Size : 16 x 32 x 4
    Volume : 12,000 Gallons
    Material :Vinyl
    Water Type : Non-Saltwater
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    What kind of pool? Gunite/plaster can handle much more chlorine than vinyl.
    A good, safe number is 15ppm for vinyl and 25ppm for gunite. Those numbers will always be safe, but depending on your CYA level, you may need/be able to go higher.
    Welcome, scott! Read the stickies, linked in my signature, about opening your pool, and also about the BBB method in general.
    You can overchlorinate, but it is really only a problem with a vinyl liner pool, as it will cause the liner to fade, and may cause premature failure.
    You need to get a good test kit, and use the readings and the Jason's calculator, also linked in my sig, to help you determine the proper amounts of any chemicals you need to add.
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    The amount of chlorine really depends on your CYA level! The CYA (stabilizer) slows down all of the chlorine's reactions: as such, the more you have the more chlorine is required to 'shock' a pool.
    Luv& Luk
    -Ted
