- Apr 25, 2012
- 47
I have the Taylor K-2006 test kit (I think it's one of the recommended ones on here). When I test my CYA, I'm supposed to poor some water into a tube until a black dot at the bottom disappears.... well, I've filled the tube up and the black dot never disappears... the water is not cloudy enough. Is that a huge problem? Do I need to worry about it immediately?
Also, secondary question, my TA is 140ppm. Is that something I should worry about immediately?
EDIT:
Actually, let me just give you all my chemical measures and you can tell me what's good or bad.
Vinyl, in-ground, ~14,000 gallon pool.
FC = 7 (Just put a lot of bleach in last night.. didn't know it would go up that much... But I think it needs a shock anyway.)
CC = .2
pH = 7.5
TA = 150
CH = 150
CYA = .....maybe 10? Not sure? The test tube only goes to thirty and that's below the top of the tube and I got all the way to the top of the tube and could stil see the black dot.
Thanks, all.
EDIT:
CC = .2
pH = 7.5
TA = 150
CH = 150
Thanks, all.
