Thread: New Pool. Don't know where to start
    I am going to have a 24 foot ag pool installed next week and I don't know where to go from there. It is about 15,000 gallons and it will have full sun all day. I am not sure if I should use chlorine pucks or liquid chlorine. When I first get it filled what are the first things that I should do in order to get it ready? What are better test strips or the drop testers? How often should I run the pump? I am getting a lot of different advice on everything. Please help.
    Thanks
    Re: New Pool. Don't know where to start
    Welcome to TFP!
    There are many different ways to do things, and many of them work. For example, you can easily run the pump longer than you really have to and nothing will go wrong aside from spending some extra money on electricity.
    The first thing to do is to get a good test kit (drop based, see the recommended test kits list at Pool School) and test the TA and CH levels of your fill water. That will tell you if either level is going to need to be adjusted right away or if there are likely to be issues with CH going forward.
    Also, do some reading in Pool School. Many of your questions, and questions you haven't thought of to ask, are answered there.
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    Krissyd,
    As I said this afternoon...first thing is to send for the test kit...see the link in Jason's sig line...that will take you to the TF test kits. Until you get it...I can help you out with my kit....Welcome Neighbor...1 more week...Then it's
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
