Thread: question on backwash procedure, with my filter
    Question for back wash proccedure with my filter's options...
    My filter doesn't have a "rince" position, but instead, I have a "waste" position...
    My problem is that, instructions I got for proper back wash proccedure, is to run 2-3 minutes on back wash position, then recyrc. position for 1 minute, then rince position for 30 second... but since I don't have "rince" position, should I use "waste" instead ????
    thanks
    12' above ground pool install "inground" - hayward pro-lx serie sp-2295 pump - hayward vari-flo sp704 - 2 x 4' x 20' fafco solar bear panel
    for polar bear living north pole, Quebec city , Canada
    Re: question on backwash procedure, with my filter
    No, when you don't have a rinse option you simply skip that step.
    Thank you Jason lion...
    I forgot to ask another simple question... what is the max. pressure on filter's dial indicator, before doing a back wash ??? I have in mind 15 PSI ?????
    thanks again
    It depends on your starting pressure. Generally you want to backwash when the filter pressure reaches 125% (or 1 and 1/4) of the clean filter pressure. The filter can actually go quite a bit longer than that, but you are losing a lot of system efficiency the longer you wait.
