Thread: Polaris vacuum coils itself
    I have an automatic Polaris pool vacuum. This thing will coil itself up withing 5 mins. I have the proper length hose and depth of hose. I have laid the hose on the deck in the sun and still nothing. Has anyone else had this problem?
    Eddie
    30 foot round pool. 4 feet deep.
    21,200 gallons
    AG
    Sand filter
    Taylor FAS-DPD Testing kit
    Re: Polaris vacuum coils itself
    You might want to check and make sure all the wheels are spinning at the same rate, also see where the jet located at the back of the unit is pointing if you straighten it out you might not coil up so fast. Another thing might be to check to make sure the backup valve is turning on and of consistently and not located to far from the unit. Hope this helps.
    Apr 2009
    Northern Virgina
    55
    Take the Polaris out of the water and check that the end of the hose that is attached to the Polaris does not bend to one side or the other. If it does, loosen the nut and twist the hose so that it bends towards the rear. Also, make sure that all of the hose bearings that connect each section can spin freely. Finally, make sure that the float is in the proper position so the Polaris is not always trying to climb or dive.
    22k gallon IG Anthony free-form pool and spa with PebbleSheen finish, Pentair WFDS-8 WhisperFlo Full Rated Dual-Speed 2HP pool pump, Sta-Rite S8D110 System 3 Grid D.E. 53 sq. ft. pool filter, Raypak R406A 399K BTU cupro-nickel propane heater, Polaris 280 pool cleaner with 3/4 HP PB4-60 booster pump, Goldline Aqua Plus controller and SWG, Inter-Fab G-Force pool slide.
    Reviving the thread, mine started to do the same, what I found is that, as the floaters on the hose decay, they don't float anymore, any section of the hose that is below water level will cause it to coil and even create knots.
