Thread: No Suction In Skimmer
    Hey everybody, I am new to this forum and need some serious help. I was trying to use a new above ground pool vacuum and during the setup I noticed I don't have any suction through my skimmer. I just brought my filter and pump from the garage and installed it. I have PVC running from the skimmer to the pump and from the sand filter back to the pool.
    Anyway when I did a vacuum test, there wasn't any suction. I hooked the hose in the skimmer and put the hose to my skin and didn't feel anything. Am i doing something wrong or is my pump acting up. This pump is 1 year old.
    Thanks for your help,
    Eddie
    30 foot round pool. 4 feet deep.
    21,200 gallons
    AG
    Sand filter
    Taylor FAS-DPD Testing kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: No Suction In Skimmer
    Did you fill the hose with water before hooking it to the skimmer?
    No i didn't. I didn't do it because it wasn't in the instructions. I will try that though. I'm still learning this pool stuff.
    Eddie
    21,200 gallons
    AG
    Sand filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Easiest way to fill the hose is to hold it over the return, put you hand on the end and transfer over to your skimmer.
