Thread: intex code 92 on salt chlorinator
    we purchased an intex saltwater chlorinator for a 15 X 42 intex pool. According to the book, we put 80 lbs of salt in the pool, dissolved it and waited 24 hours to start the chlorinator. We have been using the chlorinator for a week and yesterday it threw a code 92 (too much salt) and it won't go off. We have not added anymore salt. The only thing added was muriatic acid to get the ph down. Do you know anything about this code 92 and how to fix it. I don't understand how it ran for a week and no code, we didn't add more salt and now the code won't go off.... Thanks!
    Wanda
    Re: intex code 92 on salt chlorinator
    Welcome to TFP!
    Evaporation can increase the salt level slowly. If it was right on the edge of too high to begin with, a weeks of evaporation could have pushed it over into the salt level being too high.
    I suggest you drain out a few inches of water and then replace with new water. That will get the salt level down and should clear the error number.
    Oct 2011
    New Caney, Texas
    414
    What is your Salt level reading, you do have a salt test strip right?
    Welcome to the forum
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    Thank you! I will try that. uhhh... no I do have a salt level test kit. Apparently, the pool store I'm using doesn't care much for saltwater pools and doesn't know anything about them... I will get a salt test kit...I'm sure I will be back on here with other questions! Thanks so much for your help and I'll let you know how it comes out!!
    Oct 2011
    New Caney, Texas
    414
    See my signature to get a great test kit, the salt strips are optional and could be purchased locally but you just cant beat the TFTestkit
    Thanks! We did as suggested and drained several inches of water... added fresh and set the chlorinator. It ran with no alarms!!!!!
