Results 1 to 17 of 17
Thread: Replacing Pool Pump - Most Energy Efficient
    Hey all,
    I currently have a Pentair 1HP Pool pump (Centurion) and a 15,000 gallon pool. From everything I read, 1HP is overkill.. however, I have a timer running from 7am - 7pm to keep the energy cost down. The current pump is loud as heck the last 2 years, but the impeller is fine and I just want to replace it with a more efficient model anyway as it costs quite a bit to run even at 1/2 time (about $75/month).
    Questions are a couple:
    1. Can I get away with a 1/2 HP pump to cut costs more? It seems like I can based upon water turnover ratio..
    2. Are pumps like the Whisperflow going to save costs (they say they are energy efficient)?
    What are my best options here? I can run the pump full-time, no problem, if that is what it takes for a smaller pump and less energy costs. I really just want the most efficient pump I can get (sized correctly for my pool). BTW - very standard home, inground swimming pool - 2 jets, main drain, return. Nothing fancy.
    Hope I explained it well
    Thanks in advance!!!!
    Andy
    IG 14K gunite - built mid-1980s; sand filter 125 GPM;2.2 HP pump; TF100 test kit
    Kansas City
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: Replacing Pool Pump - Most Energy Efficient
    I would go with a Whisperflo myself and you could go with a 2 speed. 3/4 hp. might be ok. Why are you running it for 12 hours though? Cutting the run time down from 12 hours will save you money alone.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    The only reason I have been running it 12 hours is so it is up and running during daylight and when we use the pool, typically. Probably not a good reason at all
    Kansas City
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    No reason to run it that long. I would run it 10 for a few days and if it still looks good drop it to 9 then look to see what it looks like. If at 9 it still looks good drop to 8, just repeat until it doesn't look good anymore then go up in 1/2 hour increments. That right there is going to save some every month.
    excellent tip.
    Now - are there any other pumps equivalent, but less expensive, than Whisperflo? Are there better energy-saving pumps than that one?
    Kansas City
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    What you paying for energy? Do you need the whole pump changed or could you just swap out the motor for a new energy efficient one? If your rates are under .20 then 2 speed is the way to go. Not sure about dropping down in size? One of the pump guys will chime in soon.
    Wow, you guys run your pumps a lot. I run my pump once a day for about 2-3 hours after I get home from work.
    If it needs to be cleaned, I drop the suction cleaner in and let it go for 6 hours.
    Never had a problem... If it's a swimming day, I might keep it running more.
    16,000 gal in-ground
    Pump: Hayward C48K2N143 1HP 230V
    Filter: DE Triton Nautilus FNS-36
    Rates are 0.12. Thanks and hope to hear more from the 'pump guys'
    Kansas City
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Some guys run less. You want to turn over the water 1 time a day or run it as long as it still looks good. I run 4 hours a day as the swimming season starts I bump it up to 8 by the end of swim season. I have 29K so I have more water to turn, but still it looks the best at these setting for me.
    The SuperFlo is another good choice. They are about one full step smaller than a WhisperFlo with the same listed HP and cost less as well.
    The SuperFlo is available in both regular and energy efficient models. The energy efficient models always cost a bit more than the baseline models. They have more copper in them, which adds up. In the long run the energy efficient version will more than pay for it's self.
    May 2009
    Youngsville NC
    395
    I'm using one of the above Energy Effiecient SuperFlo (1.5 HP) . It's certainly cheaper to run than my old Hayward SuperPump of the same size. I'd use one of these at the least, and maybe even the 2 speed version. It would be hard to make up the cost differential for the Intelliflo's, however, with your relatively cheap electric rate.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    38,237
    What size are your suction and return lines? The Superflo is good for smaller 1.5" plumbing (although not required) while the Whisperflo is a little larger for 2+" plumbing with high glow rates.
    The 2-speed Superflo are also the energy efficient version.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Piping is 1 1/2" on supply side and return side of the pump.
    Secondary question... Looking at SuperFlo based upon recommendations (hopefully going down the right path here). I could get 2-speed or single speed. The purpose of 2 speed would be to have the pool running full-time, I would think, and save energy by running flow at a lower rate. What automation is involved with this? Would my Intermetic timer help? Is it worth the extra $$ or should I just continue to use my timer and a single-speed Superflow?
    Or... go back to Whisperflow and then downsize piping to 1 1/2?
    Kansas City
    May 2009
    Youngsville NC
    395
    The big advantage of using the low speed on a 2 speed is that you're getting half the flow rate at 25% of the electricity of the high speed.
    So let's say you have determined the high speed (only on a single speed of same SFHP) run time is about 9 hours - what you would want to do is power up the pump on high speed and run for say an hour or 2 (for the skimmer to work most efficiently), then switch to low speed for 14-16 hours for the equivalent turnover. You would also have high speed available for cleaning the pool. This does require upgrading your timer setup to be able to do this, however.
    38,237
    Or with your existing timer you just use a manual switch to select speeds. Once primed you could leave it on low speed for the required run time ... skimming should still be ok. Then just switch to high speed when you need it.
    Even doubling the run time on low speed you should save about 50% electrical power.
    ok, I eventually got the Pentair Superflow Energy Efficient Single Speed 3/4 Pump. After mulling it over for way too long, I decided that 2-speed wasn't worth it for the simple fact that i would have to do a little bit of re-wiring (which wouldn't pay off since I am selling the house anyway). I didn't want to 'step down' the piping for a Whisperflow and teh SuperFlow's seem to get good credit here.
    Thanks for everyone's help!
    Kansas City
    May 2012
    SE Texas
    48
    For what it's worth I have a Whisperflo 1- HP and I had to replace the motor last year. When on full speed (3450 rpm) the pump pulls about ~7 amps and moves, by my estimation, ~60+ GPM of water. On low speed, 1725 rpm, the pump pulls ~1 amp and moves about 20-30 GPM. I did have to re-do my timer and some of the wiring. I went with a new timer that will allow the pump to start on high-speed and switch to low but in hind-sight I wish I had just installed a switch because the pump seems to have no problem starting on low speed. I only need high speed to vacuum etc. So even though I should have to run my pump twice as long to achieve the same filtration I'm using 50% of the electricity.
    Hope this helps in the future.
    Approx. 18,000 gallons IG Gunite-replaster 2010
    1- HP Whisperflow WFE-4 with 2- Speed motor and Intermatic Timer
    Tagelus 60-D Sand Filter bought and installed 2006
    Polaris 280 with booster pump
    Hayward Swimpure SWCG up to 40,000 gallons
