No need to check anything else right now ... CYA, TA, CH do not typically change very fast and pH is not accurate with FC >10ppm.
Your pool will use up HUGE amounts of chlorine until the ammonia is oxidized.how would I know
No. Keeping your chlorine at shock value is all you care about until...but do i need to be checking any of the other numbers
mdreese said:Thanks for the help!! It seems to be working. I am holding a chlorine level longer and the cc has gone down to 2! Here's a chemistry question if anyone has time...what actually happens to the chlorine. I know it has to change somehow because chlorine is an element right...it can't just disappear...so where does it go and why does it disappear faster with sunlight?
