How do I stop pump from losing prime when cleaning basket?
prop
May 29, 2011
13
Ontario, Canada
Hi there,
(Picture attached to show my setup.)
My question is how I can prevent my pump from losing its prime when I clean the gunk from the pump's filter basket. These days, there are a lot of small leaves which end up in the pool and make it to the pump. They are trapped by the basket. However, when I try to clean out the pump's filter basket, I constantly lose prime, and I can hear constant water flow back to the pool (my pump is a few feet above my in-ground pool's water level) whilst the cover is off the pump's basket.
My workflow: turn off pump, remove pump cover, clean out basket, replace cover, and re-start pump (on high).
Should I try to turn the valve which is just before my cartridge filter (just after the pump) OFF to the pump before removing the pump's cover? I would really appreciate any help, because it takes at least 4-5 minutes to re-prime the pump after turning it back on, and I worry a little bit about running the pump while it is dry for these 4-5 minutes.
Thanks!
Re: How do I stop pump from losing prime when cleaning baske
With a setup like that you should expect to lose prime each time you open the pump strainer basket. In order to prevent loss of prime you would need to install valves on both the pump inlet and pump outlet that allowed you to isolate the pump before taking the lid off. From the look of things, doing that would require a significant amount of re-plumbing.
I have a similar issue. My pump is a good 5 feet above water level. I set all my Jandy valves to isolate the pump. The outflow is able to totally seal but the inflow I can only isolate the bottom or skimmer. I have a second basket. I isolate the skimmer and lose the bottom drain prime when I open the pump. I quickly swap baskets and close the pump lid. I then open the outflow and quickly turn the pump on. Yes it spins dry for 5-10 seconds while I then switch to isolate the bottom drain. I get the skimmer flowing well and slowly open the bottom drain so it pulls air slowly until no more air then I open it fully.
I am a little confused. Do the Jandy (black) 3-way valves not have a "closed" position that prevents flow in ANY direction?
Correct, they can't do that. They can only block one port completely, and unless you defeat the rotation stops it has to be one of the two ports that are opposite from each other.
All I have is the multi-port valve on my DE filter to control flow. When I empty my pump basket, I turn the multiport valve to "closed" this prevents water from draining out of the reservoir and keeps my prime.
Just remember to turn it back to filter before you start the pump again!!
Professed newbie here, but for what it's worth here's what I do. I have a bucket of water handy whenever I need to clean the pump basket, and as soon as the basket is back in, I dump the bucket of water into the pump and put the lid on. Be speedy or the pump drains out again. Seems to work.
I had not seen the picture. With the exception of the red valve between the three way on the inflow your setup is just like mine.
1.) set outflow to block what is coming out of the pump
2.) Close red handle valve.
3.) Pick which side to sacrifice on the in flow 3 way.
Follow my previous direction.
Disclaimer. This assumes that the two inflows on the three way are skim/bottom selectors.
My pump is about 1-1.5 feet above the surface of the water, but my skimmer / main drain pipes are routed so they loop above the entrance to the pump. There are times it still backflows out the skimmer/ maindrain, so I too just use a bucket to fill it before I put the lid on the pump.
Now for a question - would putting a check valve prior to the pump intake create more problems than it would solve ? Obviously - we don't want to prevent the pump from getting water or impeding it too much, but it seems to be that a check valve would take care of it right away if it doesn't cause other problems.
For a check valve to help it needs to be located before the pump and either fairly distant from the pump or below pool water level. Putting a check valve right next to the pump won't work reliably as it won't develop a sufficiently tight seal, air will get in and allow the line to drain. From the picture it doesn't look like it would be at all easy to install a check valve in an appropriate place.
sefrlw's approach is worth trying, as it will work with the current equipment, though it is a little more work each time compared to some of the more difficult to install options.
Thanks to you all for your valuable comments! sefrlw, I have followed your instructions, and things are *much* better now. Here is what I did just now, and water started flowing immediately after re-starting the pump! :party: This was helped by the fact that I plugged up the flexible hose port (post-pump) with a plug so that nothing can flow in or out (including air). That allowed me to turn the three-way valve OFF to the cartridge filter, preventing any flow of water back to the pump.
Here is my new workflow:
1) Turn off pump
2) Turn the outflow valve off (to the cartridge filter)
3) Turn the other valve off to the skimmers
4) Open the pump cover, remove the basket, and immediately replace the pump cover (as I do not - yet - have a second basket)
5) Clean the basket, taking my sweet time. :cool:
6) Re-install the basket, and turn on the pump.
7) Watch the water immediately flow! :whoot: :cheers:
Thanks to all of you who helped me sort this issue out. It's great to not have to run the pump dry for minutes at a time (which seem like hours as you're staring at the pump!). :goodjob:
Dang, all this time and I didn't know that simple trick! Thanks for that...
Although I must say, I prefer to let the basket drain just to catch any floaters. Am I wrong in thinking that the little time it takes to prime won't really hurt the pump? My reasoning has always been that it is not in fact truly running dry because it is getting water flow while priming...
That's my thinking as well. Mine often takes three minutes or so to prime but it gets a flow of water usually within 20-30 seconds.
Jason is right, my approach is a bit of a PIA but which is more of a PIA? Step 4 is exactly what I did before I bought a 2nd basket. I like the 2nd as I dump the clumps of stuff out but all the other that stays I let dry and then hit the basket with compressed air from a compressor. It gets it real clean.
Oh yeah just remember to open the out flow 3 way. :hammer: I have forgotten and you don't want to forget that!!
:cheers:
