Thread: Intermatic timer with heater switch useage question
    Nov 2011
    Lewiston Idaho
    76
    Hi All,
    I have a question about a Intermatic Timer I have to install when I get home in a week or so. I want to hook it up with my heater using the firemans switch. I understand how to wire it but I don't really understand how to set up the timer. I know I set the clock and the tang turns on the pump. When the "OFF" tang comes around it will trip the firemans switch and turn off the heater. On the next timing cycle what turns the heater back on?
    It is probably simple but I'm not seeing it.
    Thanks in advance
    Phil
    18,000 gallon in-ground plaster pool. Sta-rite cartridge filter, Sta-Rite Max-E-Glas II pump 1 1/2hp motor, Caretaker pool cleaner, Teledyne LAARS series 2 ESC natural gas heater 250,000 BTU. Solar Pool cover, Intermatic Timer with heater switch. Two very happy kids!
    Re: Intermatic timer with heater switch useage question
    Just as the off tang hits the fireman switch first and the main switch second, the on tang hits the main switch first and the fireman switch second.
    Nov 2011
    Lewiston Idaho
    76
    Well ok then I knew I was probably over thinking the whole thing!
    Thanks
    Phil
